Question about Garden
Briggs & Stratton 6.5 hp Quantum
Blowing gas mist out of carb when running.
    President:
  • 1,388 Answers
The problem that you are describing is caused by intake valve not seating correctly. I see this problem on engines that have many hours of use or lack of service. You may be able to grind /reseat /adjust valves but usually requires new guide, valve and spring. Enjoy
Posted on Dec 10, 2008
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
I have a Briggs Stratton 17.5 it backfired now won't start . now blowing gas out carb
sounds as you need to do a compression ck on the heads to see if you have a blown head gasket, If it does let me save you a lot of time n money don;t go 4 the head resurface and new gasket it won;t last long briggs sells a "short block" thats your best bet !!!!!
Jun 04, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Oil blowing out of carb. gas in oil ohv engine
carb needle valve stuck open clean carb possible bad float dont run with gas in oil
Jun 23, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
2,069 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
