Question about SanDisk Sansa e250 MP3 Player
Won't Delete Music
So I can add songs all day long on my Sansa, but it will not delete them. It will at least connect to RealPlayer, if I try to delete any music through there, the Sansa just freezes up and restarts itself. It does the same thing if I even try to connect with either Rhapsody or Windows Media Player. Not sure what to do, have tried everything I can think of. At this point I would be willing to format it and start all over, but it won't even allow that.
  • benny reyes Oct 03, 2008
    cant delete music.i can only put music but never delete it.
  • 758 Answers
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Posted on Oct 03, 2008
How do I remove a song or songs from my Sansa SanDisk mp3 player model m240?
There are 2 ways to delete music files. You can delete them from the player directly or
using the computer.
To delete music files directly from the Sansa player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your music files are stored.
4. Highlight and delete the music files or folder.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | SanDisk Audio Players & Recorders
How do i delete songs off my sansa m230 so i can add new music
Connect the Sansa to your computer using the supplied cable. Open up the operating system's explorer window. The Sansa will show as either a Sansa or a removable hard drive, depending on the USB mode. Either way, open it and you'll see a folder named "MUSIC". Open that. You can either delete entire albums or navigate into them and delete individual tracks.
Mar 10, 2010 | SanDisk Sansa m230 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
My sansa 1gb won't let me delete songs
To delete files directly from the Sansa player, follow these steps:
1. In playback mode, press the Submenu button.
2. Select Delete.
connection.
3. Locate the folder where your files are stored.
NOTE: Music files are stored in the MUSIC folder. Voice recording files
are stored in RECORDING folders. Photos and Videos are stored at PHOTO
and VIDEOS folders, respectively.
4. Highlight and delete the desired files.
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
I WANT TO DELETE ALL SONGS OFF MY MP 3 PLAYER SO I CAN ADD ALL NEW ONES
To delete files using your computer,
1. connect your sansa to the computer,
2.select open device to view files using windows explorer on inital contact,
3.select the place you want music deleted from,
4.highlight and delete the music files or folder (if your lucky),from
My Computer/Sansa e270/Internal Memory/ Music folder!
you can also manually delete files from the device if this does'nt work..........
May 11, 2008 | SanDisk Sansa e200 MP3 Player
Help Me! Sansa m240 say only 'Finalizing Update" then turns off
Oh lol this is easy. just go onto realplayer or something then go on the tab burn/transfer then it will tell u your songs delete them all. then try turning your mp3 on and going to "settings" then go all the way to the bottom of that page then click "reset all" then go back to windows media player and put your songs on.
Dec 23, 2007 | SanDisk Sansa m240 MP3 Player
I cant change any of the songs on my mp3!!!
Try it in your realplayer and see if you can add and delete there after you syncronize it, Try that see if it works for you, Hope so, also if you do manage to hook up with usb go into the setting and check and make sure that all options are check that you want to work, If you see that there is a way to let the sanddisk manage music on my sansa or you can do it, If sandisk is managing it, It will not let you add music, so change that and see if that helps ya out, You may also notice that there is another way to connnect in the sandisks options again, I hope that gets you up and saving music, Take Care and Happy Holidays
Dec 15, 2007 | SanDisk Sansa m240 MP3 Player
RCA M202A
I found the best way to delete your mp3; go to start..find you device in "my computor" it will be a generic drive. right click and go to "format" click and it will prompt you to delete "playlist".."audio" or "music". However it will erase everything on your mp3 and allow new downloads. if you want to save some files; Plug mp3 in usb port..you will get prompt to define which system to play files. I use realplayer. scroll down until you can select "rca (G)" click "view" your mp3 will load and display all songs..you can then select and delete any or all, right click and choose option. To load; choose burn/transfer scrool down on the leftside to rca (G) and you can choose from you music menu ( I suggest making a playlist first to indentfy what songs you prefer, you can always add more from all music menu. add any files that you like until full. depending on song generally about 50 to 65 son on the 512 model. Do not worry about too many songs.. NO harm....they just won't fit.... I hope this help anyone with this problem
Nov 20, 2007 | RCA M2000 MP3 Player
Deleteing songs
You can delete them thru My Computer. Double click on the Sansa (m200), inside you will see a Music Folder. Inside is your individual tracks, separated by album names. You can add or delete all music from here. Best of Luck.
Oct 09, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
Deleting
You can manually delete the music thru My Computer. My Computer>Device Name (c250)>Media>Music You can see all of the music by albums and delete what you want. Please add to this question if you need more assistance. Best of Luck.
Sep 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
