Question about HP L1702 17" LCD Monitor
Why can't I change to native resolution?
For some reason I cannot change my monitors resolution up to 1280 x 1024 resolution, which is supposed to be native.  I have tried in Ubuntu and Vista.  For some reason in both OSs, it shows that it is a Lite-on monitor and is only capable of 1024 x 768.  Can a monitor somehow break and not allow me to go to full resolution, or is there just a button I need to push?
    Scholar:
  • 155 Answers
Try your monitor on another computer. it could also be your video card. try swapping parts if possible to determine the culprit.
Posted on Oct 03, 2008
Adjust the video height on MAG lt716s computer monitor
don't worry overly, the shapes of things will be altered as you change the resolution. The main preset resolution s have different
aspect ratios
1920 x 1080 is 1.77/1
1600 x 1200 is 1.33/1
you change aspect ration according to your selected resolution.
Your monitor will have a native resolution at which everything looks normal, .......If you vary from that resolution things will obviously change.
Jul 16, 2015 | Computers & Internet
Tip
Flickering LCD/CRT monitor screen or unstable image fix
If the screen flickers, make sure the display settings in Windows match the native resolution and refresh rate for the monitor. You can find the native resolution of a flat panel display in the specifications, in the printed material or on the box that came with the monitor. Some common native resolutions are 800 x 600, 1024 x 768, 1920 x 1080, and 1680 x 1050. To find out more about optimal screen resolutions see my tip on resolutions here.
The most common refresh rate for LCD monitors is 60 Hz. This normally cannot be changed for flat panel displays using Plug and Play settings. However, if you are using special video software to increase or decrease the refresh rate, change the refresh rate to match the default refresh rate specification of the monitor. To find out more about refresh rates see my tip here.
STEP 1
To change the screen resolution and refresh rate settings in Windows, do the following:
- In Windows XP
See my tip on setting up the optimum screen resolution for Windows XP here.
- In Windows Vista
1. Click Start, and then click Control Panel .
2. Find the Appearance and Personalization area, and click Adjust Screen Resolution .
3. Move the slider bar until the screen resolution matches the native resolution.
4. Click Advanced settings, and then click the Monitor tab.
5. Select the Screen refresh rate that matches the default rate for your monitor (if it is not already selected).
6. Click OK, and then click OK again.
If you cannot select the native resolution or the native resolution is unavailable, continue to the next step to update the drivers for the graphics adapter on the computer.
You can get the latest updated video drivers from the video hardware manufacturer's Web site. Here is a list showing some of the video hardware websites:
Check for NVIDIA video driver updates at NVIDIA Home Page.
Check for ATI/AMD video driver updates at ATI Home Page.
Check for Intel video support and downloads, Intel Downloads.
After updating the video drivers, go back to Step 1 and try to change the screen resolution again.
Note: If you cannot select the native resolution after updating the video drivers, the graphics adapter in the computer might not support that resolution and may need to be upgraded.
If after changing the resolution and updating video drivers the flickering persists then check the video cable connections. Unplug the cable and inspect the cable for damage. If the cable is damaged, replace it with a new cable. Try to use cables less than 3 meters (10 feet) long.
Monitors are sensitive to magnetic fields so have a look at the environment around the monitor. Speakers, florescent lights, fans, cell phones, radios, and any other electrical device can cause flickering. Temporarily move electrical items away from the monitor to see if they is producing a field that causes the flicker.
If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
To see if the video coming from the computer is causing the problem, temporarily connect the monitor to another computer. If the flicker is gone when the monitor is connected to another computer, the graphics adapter hardware on the first computer might need to be upgraded to use the monitor.
If however the flicker remains then the problem lies within the harware of the monitor itself and is not a software problem. If you have bought this monitor fairly recently then I suggest you take it back to the place of purchace and have them test it. Some monitors carry 3 year warranty support so if you bought it within the warranty period specified by the reseller I suggest you see if you can get refunded or have them swop it out.
on Jun 08, 2011 | Computers & Internet
How to increase resolution from 1024 x 576 pixels to 1280 x 600 pixels. I tried to change it by clicking start>control panel>display>settings but won't get desired results.
make sure wether the disply of your monitor and graphics card supports the resolution if the monitor doesnt support sthe resolution you will not be able to increase the resolution the mobilor becomes black
Sep 04, 2011 | HP Mini 1000 Netbook
The display is not fit on the monitor help me how to fix it thanks!!! ayanblink@yahoo.com
You need to set your PC video resolution to the native resolution of this monitor, which is 1440x900 @60Hz. Mkae sure to to have correct video card driver installed and may also need the driver for this monitor if the native resolution is not listed.
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 09, 2010 | Acer AL1916W 19" LCD Monitor
My Viewsonic VG2230wm refuses to use its native resolution of 1680 x 1050. Whenever I select this resolution, it registers on the computer display settings, but when I check on the monitor display panel...
You will need to adjust your monitor settings in the NVidia control panel. You can get to this by right clicking somewhere in a blank spot on your desktop and then selecting it from the menu. You will want to go into the Display section. If you aren't able to see that section, change from "Standard" to "Advanced" settings at the top of the screen.
Dec 31, 2009 | ViewSonic VG2230WM LCD Monitor
How do i adjust the screen resolution on my monitor?
right click on desktop then go to the properties > select settings> then change your screen resolution whatever u want.
Dec 11, 2009 | Cars & Trucks
My LCD s dose not match with its native resolution
Well, how would you like us to help? I suppose the only way to getting the native resolution to match is by buying the same or similar monitor.
Jul 08, 2009 | Computers & Internet
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Apr 05, 2009 | Acer AL2216W LCD Monitor
Resolution of the text
What is the resolution that you are running the monitor at? There are two possible reasons that come to my mind.
1. You are running at a non native resolution. Based on your LCD spec you should run it at 1280x1024 resolution to have very sharp text as you normally expect from LCD's. However if you have set another resolution (say 1024x768) the text is blurred and this is a known issue with LCD's, which unlike a normal CRT monitor will get blurred running at any other resolution :(
2. You have not installed the monitor driver, hence again this limits your resolution and windows only allows you to select a resolution that is non-native (Meaning since the driver file is not there the operating system may not allow selecting the native resolution the monitor should run at). You can find the driver file at the samsung site. Its a common driver file for all LCDs.
Dec 12, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
HP L1702 17" LCD Monitor Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
