GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
I am replacing a "clutch-type" GE washing machine motor with a newer "clutch-less" motor. Does the new motor need a Capacitor and Relay? If it does need these, how can I get a wiring schematic or diagram showing how I connect the Motor, Capacitor, Relay, and Washer to each other?
The replacement motor is a used one with only a partial wiring harness - sadly for me, it did not come with a capacitor, relay or wiring instructions.
GE Washer Model: WCSE4160B1WW
Original Clutch-type Motor: 5KH61KW2516HS
- this motor had a rectangular connector block with 6 contacts/wires
Replacement Clutch-less Motor: 5KCP160FFA001AS
- this motor has a square connector block with 7 contacts/wires
  • 1 more comment
  • wardw1946 Oct 04, 2008
    To: SearsTechToo
    Thanks for you comments.
    From some other online searches, I've seen several times that the WH20X10009 and the WH20X10006 clutch-type motors were replaced with WH49X10035 Motor Assembly which has the WH20X10019 clutchless motor, WH12X10212 Capacitor, and WH12X10213 Relay... basically when they get rid of the clutch, there is a starting torque problem, so the relay and capacitor give the motor an extra boost for starting... here's a sample of the kind of words I've seen:
  • WH49X10035
  • * Includes motor (WH20X10019), capacitor (WH12X10212), wiring harness, and mounting hardware
    * Clutch not included
    * Used on 1995 and later GE brands clothes washers
    * Replaces part numbers WH20X867, WH20X10009, and WH20X10006
    * On Diagram, #630
    So that's why I went the way I did. The 7th extra wire coming out of the WH20X10019 clutchless motor is gonna go to the relay or capacitor somehow and then from the relay it will connect to the washer control circuit with same 6 original wires I think. Since I posted the question, I got lucky recently and found an electrical guy who accomplished the same upgrade about a year ago, and he is searching for the wiring diagram he used. Hopefully I can repeat his steps.
    I didn't really want to go the "used" route either, but I could not see spending $263 to put a new motor into a used washer. If the used motor, capacitor and relay work out for me, I'll end up spending only around $75... and I'll be getting rid of any future clutch problems but I still need to find the wiring diagram for the WH49X10035 Motor Assembly to be able to pull it off... again, thanks for your feedback!
  • Anonymous Feb 25, 2009
    Hello, did you find out what to do with the extra wire? I know what you mean....the extra wire is BLACK on the new motor, 7 wires go to the control board.
    On the old Motor: wh20x10009, there are Six Wires going to the control board...it does not have the extra black wire that the new motor does
  • Anonymous Mar 15, 2014
    This washing machine (located in Havana, Cuba) exploded the capacitor, a piece next to the motor. My friend has asked me to buy the replacement part: Capacitador 33 + 14 uf 300 volt. Can you tell me WHERE I might find such a part? I am located in Central Mexico but can order and have shipped from anywhere. Thank you!
      Novelist:
      Champion:
    • 261 Answers
    The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
    I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
    Posted on Oct 03, 2008
    • John Robbins
      John Robbins Oct 04, 2008
      Cool, the clutch does save wear on the motor and is a basic two speed transfer case.
    We just moved our washer to a new house and now it doesn't work. It fills with water but thats all it does.
    It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
    Jan 22, 2010 | GE 3.2 cu. ft. Washer
    My wilkins servis washing machine will not wash cycle
    It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
    Jan 03, 2010 | Washing Machines
    Agitotor not spinning during wash cycle M/N: LSR8244EQ1 Machine less than 10yrs. old, good shape
    Jan 02, 2010 | Whirlpool Washing Machines
    Washer will fill and spin but will not agitate ge top load washer wwsr3130w0ww
    Jan 02, 2010 | GE WBSR3140DW Top Load Washer
    GE Profile , when door closes comes on , but does not appear that agitator is moving.
    Jan 01, 2010 | GE Profile WPRE6100G Top Load Washer
    Washing machine hisitates to agetiate and doesnt spin fast
    very possible motor brushes need replacement or if a squirrel cage motor check the capacitor.
    Sep 15, 2009 | GE WSXH208A Front Load Washer
    GE Profile washing machine not finishing cycles
    the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
    Selector switch
    Clutch assembly
    Drive motor
    Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
    Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
    Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
    May 07, 2009 | GE Profile WPRE6100G Top Load Washer
    GE Prodigy Washing machine making clunking noise
    One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
    May 03, 2009 | GE Washing Machines
    Ge wasr311owoww profile washing machine wont spin or agitate
    if the motor is spinning properly and you don't get any burning smell while the machine is in spin mode.then no need to replace the motor.only replace the clutch.this will help.motor goes bad very rarely in this units. ------------- for parts you can get it from ---- www.repairclinic.com ------- thanks.
    Feb 23, 2009 | GE Profile WPRE6100G Top Load Washer
    Washing Machine Motor Missing Wire Harness
    Go to www.repairclinic.com and order the complete wire harness and cap.
    Easy place to do business.
    Jan 23, 2008 | Washing Machines
    Washing Machines Logo
    5,546 people viewed this question
    Top Washing Machines Experts
