Question about Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver
Phone log jumps to older time on mailbox and freezes up
When I go to my phone log the icon jumps to the mailbox setting for 11:30 a.m. (earlier today) and freezes up. The same thing happens when I try to dial a phone number, again the icon jumps to the mailbox icon setting for 11:30 a.m. this morning and freezes up. I've turned on and off the phone several times hoping for a reset, but this hasn't worked. Is my phone haunted? Is there a solution?
  • 31 Answers
The short term solution is to do a soft-reset on the phone by removing the battery, reinserting it, then powering on the phone.
The Pearl has known memory issues since it has less internal memory due to its size. When it begins to run low on memory the phone acts crazy, and it can even begin deleting information. Performing the soft-reset will let the phone realize it does have free space to use, but this is really only a temporary fix.
In the long term you've got a few things yous hould do:
- Invest in a MicroSD memory card. Then you can have a lot of your stuff stored on the card thereby freeing up the phone's memory.
- Delete any applications you aren't using or don't need. This is done through Options > Advanced Options > Applications. Highlight the program you want to remove, press the menu button and choose to delete.
- If the phone has the Facebook applicate then it is STRONGLY recommended you remove it. It is constantly trying to connect to the Facebook service, which uses a lot of memory and decreases the phone's performance.
- Go to Blackberry's website and run any software updates available for the Pearl (there are a few!) but make sure to back up your information first!
If all else fails, back up your information to your computer and perform a hard-reset. IMPORTANT - A hard-reset will erase ALL information on the phone so it is VERY important to back up your information!! Once you've backed everything up, you can perform the hard-reset by going to Options > Security > General Settings, then press the menu button and select the Wipe Handheld option.
Posted on Oct 04, 2008
Where is call log on my phone
What kind of phone do you have? Most older phones are on the call bottom, some are in the call log section. And some are in the settings. Galaxy has a icon on the bottom that looks like a phone, follow the icons on the top to recent to see the log. If you need to delete the log, hit the button on the bottom left of the phone and get the menu and delete.
Dec 11, 2017 | Cell Phones
Can't access the General Delivery Mailbox
To retrieve message from mailbox behind the phone:
Feature 981
Enter your password as asked
To retrieve message from mailbox that is not behind the phone:
Feature 981
Press OTHER
Log = Your ext # and password together
Press OK
Example if mailbox 100 and password 1234 then your log = 1001234
Example if mailbox 221 and password 5678 then your log = 2215678
Oct 15, 2012 | NorStar M7310 Corded Phone
I can't get passed primary greeting recording.
Hi there Moodymar,
One thing you can try is logging into your mailbox as you would calling into your vmail system externally.....dial access phone number....here prompt.....dial ** mailbox number, then password. ""Sometimes"" this tricks it and you can get in. Question, does any one else have the same problem? If no, then unfortunately you have to get the system administrator to delete your mailbox and re-create it, you will loose msg's.
The nortel vmail systems are not forgiving if something doesn't sit right with them.
You also mentioned that mbox is full, do you here the system announce that?
Also make sure your mbox has not been set as a ""Information mailbox", maybe a silly question, just something to clear out of the way (this type of box does not record greetings).
Another thing, typically when mboxes are created on Norstar vmail systems the extension and mbox numbers match. Make sure you ext and mbox number match, cause 99.9 % of time they will. That small percentage of time they don't cause's confusion for the end users.
I know this is a lot of stuff, but, one last thing, to make sure your phone is operating okay, have someone else try logging into thier own vmail on your phone, or a couple of people
Jan 17, 2012 | NorStar T7316E Corded Phone
Hi, i've recently got a sony ericsson experia x8 mobile phone. My boyfriend logged in to his own personal e-mails on it and now we don't know how to log back out of them! So now i get all alert's sent to...
yes i would not worry to much about this as this can be done with most phones he did not breach any security on your phone he just simply has his mailbox set up on the phone but he cannot read your mailbox if you have a password that is dont worry ,he would have had to set this up on your phone just go into settings /mailbox and delete the account
Jan 30, 2011 | Cell Phones
My phone is Norstar M7324. I can't get voicemails. I have customers called and left voicemails but I can't receive them. I use Feature 981 and it tells me no messages everytime. Any advise? Thanks.
Maybe the callers are leaving messages in the General Delivery mailbox? From your phone, dial Feature 981, when it prompts you for a password, press the button under "OTHR", and you will be prompted for the log. (The log is the mailbox and password combination for a mailbox not assigned to your phone.) If you use 2-digit extensions, the General Delivery mailbox is #10, for 3-digit extensions, the mailbox number is #100, and etc. The default General Delivery mailbox password is "0000". So, using 2-digit ext's, the log would be 100000, then press # or OK and you can retrieve the messages. Write back if you need more help.
Mar 16, 2010 | NorStar M7324 Telephone
Describe your NorStar M7100 Corded My phone display shows ?message for you?, but I have no new or old messages. The display should show the date and time. We did reinitialize the mailbox and the same above...
Your phone may have another mailbox associated with it, like the general delivery mailbox which can be mail box 100, try logging into 100 with default password of 0000. I am assuming you have 3 digit extension, if 2 digit login into mailbox 10.
Dan
Jul 02, 2009 | NorStar M7100 Corded Phone
Also trying to initialize voicemail, says Feature 983 inactive
Feature 983 gives cess to System Administration; This Feature will ask for a Log:
Feature 981 Opens A Mailbox your mailbox # should consist of three digits. First what is the name of your mailbox system?
Jun 30, 2009 | NorStar M7324 Telephone
Mailbox problem
The following instructions will only work if your System Administrator password is set to the default. Usually the default is 0000.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Reset a Mailbox Password:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
Oct 21, 2008 | Nortel T7316E 2-Line Corded Phone
Length of time phone rings with incoming calls
get your mailbox number then type in **61*44then mailbox mumber*11*then a two digit number between 00 and 30 (seconds delay).
Feb 19, 2008 | RIM BlackBerry 8800 Smartphone
Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
50 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
