I need to know where I can find a trouble shooting guide for a Trane mod0944 module for a blower motor (mot09675)
  • Tommy Duke Oct 04, 2008
    Thanks for trying. I didn't explain my problem very well but, its not a heater its a variable speed air handler . The module is a dc pulse motor module
    I found out it was the module at the motor. I took it apart and capacitors fell in my hand due to moisture inside the the air handler
    I do thank you for attempting
    Tommy Duke
    Scholar:
  • 121 Answers
Trane is very picky about being a Trane dealer before they will even talk to you. But as far as trouble shooting a module there no guides. If the flame comes on then the fan does not shutting down the furnace it could be a fan relay failure or the fan module failure. The modules propose is to allow the furnace time to heat up before bringing on the fan so as to not blow out cold. Or the fan motor it's self could failing
Posted on Oct 03, 2008
Where is the blower motor relay located. Is it in the blower motor control module?
Are there any hvac trouble codes ? Did you check voltage and ground for front blower motor, with controls turned on? I believe the purple wire is voltage and black wire is ground. If good voltage and ground with no blower action, suspect the blower motor.
With auto hvac didn't see relay, saw blower motor control processor, at control processor, did you check voltage and ground?
As far as replacing the blower motor control processor, that appears to be a very involved procedure. I can't lead you step by step to remove and replace.
Auto.com
Has free repair info, you have to register your vehicle, it is free. Then click on vehicle repair guides, take a look.
If you want wiring diagram, let us know?
Apr 21, 2016 | 2002 Cadillac Deville
My blower won't work
There is a blower motor power module that controls the speeds ,There is also a blower motor relay in the under hood fuse box . Dodge calls it intelligent power module.You can go to you tube a search blower motor trouble shooting an repair .
Dec 02, 2015 | 2001 Dodge Caravan
2000 expediton bower motor comes on high when off radio and wipers flash on and off what exactly should we fix
It sound like you have a wiring problem somewhere behind the dash an the only way to know what to fix is by trouble shooting . Find wiring diagrams for the wipers , radio , blower motor an see if they share connectors in the wiring harness or see if wiring is rubbed through . You may have to take the dash apart to get at the harness . Go to you tube an check out some basic electrical trouble shooting videos an how to read wiring diagrams , an you mite also check out how to use a DVOM -digital volt ohm meter . You mite also have the body control module checked for codes , because the wipers are monitored by it. It's actually called a GEM - generic electronic module . It's not that easy , What Exactly should we fix ! Your best bet is to take it to a ASE certified repair shop or a automotive electrical repair shop.
Dec 02, 2015 | Cars & Trucks
Can I get a trouble shooting guide for a Poulan Pro leaf blower bvm200vs
the owners manual, available online has some trouble shooting tips...
Oct 18, 2014 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
Blower not working. have replaced the motor resister. what next? Does anyone know how to trouble shoot this system?
REPLACE BLOWER MOTOR RELAY.HOOK TEST LIGHT SEE POWER GOING TO BLOWER MOTOR IF YES BLOWER MOTOR FAULTY.IF NO POWER GOING TO BLOWER MOTOR, FAULTY RELAY, FAULTY CONTROL SWITCH OR POOR GROUND AT WIRE TO BLOWER MOTOR.
Jul 05, 2011 | Chrysler Voyager Cars & Trucks
2001 nissan maxima se--trouble shooting for blower motor resistor
if your blower motro only works on the #4 setting you need a resistor.cheap and easy to change.located next to blower motor under pass. side of dash.two phillips screws secure it.if it fails again replace blower motor as it is drawing too much current and overheating resistors.let me know how it turns out.
Feb 20, 2011 | 2001 Nissan Maxima
The heil furnance ignitor module error code
Remove the cover from the control box,there's a guide posted inside to trouble shoot the codes.
Jan 02, 2010 | Cross Furnace Draft Inducer Blower 115...
1997 cadillac catera blower motor problem
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800c1846
good luck. Free online guide to your car.
Thank you so much for checking your fuses first. Its so refreshing to know people still know how to do basic trouble shooting.
Dec 06, 2008 | 1997 Cadillac Catera
Heating & Cooling Logo
290 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
