I have an RCA 52" CRT rear projection television. Every time I press power the green power light on the tv flashes on then goes off, three times but won't come on. Sometimes it will but now will not.
  • 5,138 Answers
Look on Deflection board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v these three capacitors are located up front of board they are green with gold writing on them also you will notice most of the time they bubble up on top when they should be flat straight across the tops.
Posted on Oct 03, 2008
I HAVE A 52' RCA HDTV THAT WILL NOT TURN ON ,AT TIMES IT SEEMS LIKE IT WILL TURN ON BUT THEN GOES BACK OFF,CAN ANY ONE TELL ME WHAT THIS PROBLEM CAN BE
sounds like the power caps CP150 CP120 and CP114 on the deflection board. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit also comes with instructions.
Mar 15, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv green light flashes on and off 3 times. Never comes on.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
check the components as given above and if necessary replace the components to solve the issue.
This will help. Thanks .please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | RCA D52W19 52" Rear Projection Television
52" RCA Rear Projection TV. It doesn't turn on right way.
bad capacitors in the power supply is most likely.
could have bad ihvt and output transistor
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
With TV OFF Press and hold vol- and ch- at same time untill tv comes back on release you should now be in Service Menu.
Feb 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca projection tv
Capacitor on Deflection board cp150 2200uf 16v if it is puffed up on top it is bad 2 more caps cp114 cp120 220uf 35v replace them if cp150 is bad.they are green with gold writing on them.
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" second time in the shop in less than one year, won't stay on, green light flashes 3 times then goes out
try changing the cap 150 on the same board as flyback transformer this should help with the tv not staying on.
Jan 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
