Question about Maytag MSD2656G Side by Side Refrigerator
No water from door outlet
Model # msd2454grw Water does not come out the door opening. The light is on and it has a slight hummm when i push the area pad for the water. About 3 months ago, I have replaced the filter, drained and locked and unlocked the button. I removed the filter and put a cup under the filter nozzel and closed the door and tryed the water , no water . I looked behind the fridge and no kinked lines. help
  • 943 Answers
Hi. Thanks For The Question. I Would Check The Water Valve. Disconnect The Water Line From The Valve ,Leaving The Water On. Now Push The Water Button. If Water Flows You Have A Blockage. If Water Does Not Flow. Replace The Valve .Thanks The Appliance doc
Posted on Oct 03, 2008
Our Magic comfort has error message :ventilate" but when I press the water button all I get is a hummm.... no water. we tried to get hot water for the first time in years but didn't open the steam wan
Dear Ken, my magic comfort plus had similar problem with incorrect read out and not performing, not specifically with the hot water.
Try resetting the machine to full factory settings, and try again. As the water comes out of the steam wand, obviously that cannot be a blockage fault unless you are not getting steam either.
Nov 24, 2014 | Coffee Makers & Espresso Machines
GSL25JFXNLB water flow to dispenser seems to freeze up. I leave light on in dispenser area and seems to free it up. Any particular problem with the dispenser?
Some models had a service kit for a dispenser heated applied at the water outlet on the door. Before you go hunting for this kit, open the freezer door and knob with your hand (like a door) on the inside door liner. Does it sound hollow or solid? If hollow the heater will work for you, if solid, the heater will not work because the inside of the door is frozen and only fix was to replace the door.
I hope this helps, good luck
Nov 02, 2013 | GE GSL25JFXLB (250 cu ft) Side by Side...
Water won't come out of the dispenser. I Checked to the door and the water works to the door, but won't come from the dispenser.
open the door, place a blanket over the opening to keep yopur food cold, and use a blowdryer on medium to warm up the inside of the door in the area where the water comes out. It should thaw the line.
I had the same problem yesterday, and the water was flowing normally in about 10 minutes.
if you dont have a dryer, it will thaw on it's own, but may take a little longer
Dec 10, 2009 | GE Profile PFS22 33" Artica French Door...
Cloths stink, towels not soft. Can I increase the amount of water used per cycle? How? thanks, jim maxwell
Make sure there are no leaks from the machine. Look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose and door rubber is completely clear of debris and soap scum build up and check that the filter is clean.
You can initially use a bathroom mould and bacteria cleaner to get rid of the immediate problem or wash using a bleach solution made up from 1 part household bleach to 10 parts water. Place this in an aerosol spray bottle and spray the affected area and leave for 10 mins then wipe away and rinse with clean water.
  1. To keep the machine clean of waste or mould build up and to keep any bad odours away
  2. Remove all items from the washer.
  3. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
  4. Close the washer door and dispenser drawer.
  5. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
  6. Press Start and allow cycle to complete.
  7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
  8. Repeat the cleaning procedure monthly
Also from your description it sounds as though you need to use a water softener (washing soda) or use slightly more deteregent and possibly more fabric conditioner inthe wash. Also washing performance can be increased by using slightly higer temperatures and / or a bilogical detergent.
Nov 09, 2009 | Maytag Neptune Washer
Why am I not getting any water from door dispenser for model GSS23KGSA BB
Pull refrig out , and remove the back panel . At the water valve (piece the wall water line connects to , push up on the white ring and pull the LARGER line from the valve . Activate the water dispensor and see if water comes out of the valve . If no water , replace the complete water valve . If water comes out , reinstall the hose by pushing back into valve , and remount valve and rear panel . Push refrig back into place . Remove the bottom kick plate and disconnect the water line about 6" under front , from the coupling (pushing in the ring and pulling hose ). Press for water again . If no water comes out , probably frozen resevoir behind the refrig crispers , so turn refrig temp slightly warmer for a few days , to unthaw (or use hairdryer) . If water shoots out from hose , then water line inside door is frozen . This would be a more difficult procedure to follow . You can try adjusting freezer temp slightly warmer for a few days to see if it will thaw . If it doesn't thaw , come back to this thread with " water in door frozen " and myself or another expert will be glad to help you .
Sep 09, 2009 | Refrigerators
Cleaning icemaker/water dispenser in door of freezer-its filthy
Use a butter knife between the dispensor grill and the lower portion of the cover . Push down and slightly outward on both sides of the lower cover . Then lift upwards after the bottom portion is free . There are 2 plastic tabs holding this lower portion on .
Aug 23, 2009 | Refrigerators
Water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Jan 13, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Maytag MSD2656G Side by Side Refrigerator Logo
123 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
