Question about Epson R1900 Printer
Continuous Ink System Epson R1900 "Ink on" light illuminated
I am trying to install CIS for Epson Stylus R1900. One of the "ink on" lights stays on. The other 7 turn off. Have tried adjusting/reinstalling. The CIS has auto reset chips. Is it likely that my chip is bad on the one cartridge?
Hi, the most possible is that your chip on that cartridge is broken or damaged. You may need to replace a new chip.
Or you didn't contact well the chip with printer contact pins. Try many times.
If still problems pls feel free to ask me.
Posted on Jan 29, 2010
  • 3 Answers
Your R1900 chips has problem, you can try
their chips works well
Posted on Mar 30, 2009
I have an epson stylus tx115 multifunctional printer with the continuous printing system installed . there is plenty of ink in the printer . A red light is flashing telling that there is not ink , I...
You must reset the cartridges chip. About " there is plenty of ink in the printer " you mean ink leakeage in to printer ? If yes, first thing is to clean the printer ( the ciss is not instaled corectly) and reinstall the ciss. The ink tank of ciss should stay at the same level with the printer.
Dec 31, 2017 | Epson Stylus Photo R320 InkJet Printer
I have the R1900. Under all chip resetter so far I have not found one the mentions the R1900 or it's cartridges To87X. I know the cartridges has two chips one on top and a smaller one under it. What chip...
Have a look at this Adjustment Program Epson R1900 - Resetter Epson R1900
I have not tried but I do not believe there is a hardware solution. Also check this site:
They sell a set of refillable cartridges with an auto reset feature. They have a video which is also posted on YouTube which shows the refilling of their system.
Also found this which you may find of interest:
Would be interested to hear if the softwareresetter works out.
Dec 29, 2010 | Epson R1900 Printer
Ink cartridges cannot be recognized
The printer must detect unique 'chips' on the ink cartridges before it will print. Non-Epson ink cartridges may not have the right chips. Or there may be a bad electrical connection between the carriage assembly and the chips when cartridges are in place. Anything preventing the chips from being electrically connected, (including dirty contacts), can cause the error.
In my case the chips were not staying in place on the ink cartridges. Since I am using a CIS (Continuous Ink System), the chips had been replaced, but were not staying in alignment with the contacts on the carriage. I used a very small amount of hot melt glue to secure the loose end of each chip to each cartridge. I have not received the error message again.
Oct 26, 2010 | Epson Stylus RX580 InkJet Photo Printer
Changed from cartridges to cont. ink system. Now
Hi Dave,
Chances are the problem is that you haven't removed the travel plugs that allow air into the reservoir part of your CIS. This is vital because the air needs to replace ink used up in printing and if it can't do this the air creates something of a vacuum that holds back the ink.
Also worth checking that you haven't got any crimped (folded) tubing or clamps that are still engaged that shouldn't be.
Hope that helps..
Mar 26, 2010 | Epson Stylus Photo 2100 InkJet Printer
Blinking Power Light
Try to wiped clean its Ink connector and ink chip. Could be dirty contact.
Hope it helps
Apr 05, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson d88 printer just floods the paper with ink
Sounds a lot like you have an ink pressure issue and at a guess you are using a CIS (Continuous Ink Supply) system.
I would refer back to the documentation that came with your printer and make sure that you are not overpressuring the printhead with the ink reservoirs set too high or some part of the priming process has been missed.
More information about your printers setup would definitely help ID more specific issues that could be causing this.
Mar 24, 2009 | Epson Stylus D88 InkJet Photo Printer
Compatible ink
yes i have a epson rx560 i brought a contiouous ink system the thing you must watch out for when buying copy ink is that they work with all modles or rx560 as some ink will only work befor printer made before 1 march 2007 and some will only work after made 2007
but the continuous ink system will work wit all models i can get cis for £45 plus postage and come with 6 x 100 ml ink contact me if your intreasted
Oct 11, 2007 | Epson Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
Open Questions:
See all Epson R1900 Printer Questions
Epson R1900 Printer Logo
1,256 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
