Question about Toshiba 32HF73 32" TV
Blurry picture the picutre is blurry on any type of setting i try i adjusted the flyback and it got a little better there is also alot of stactic coming from the tube color is perfect i think it is coming from the fly back so i tried discharging the tube and reconnecting the wire to the tube and no luck i need help
  • Bryan Howald Nov 19, 2008
    fixed it went ahead and replaced the houtput with it its got a great pic now thanks
  • 10,594 Answers
Ok, if you require Fly back Transformer for your Toshiba TV, its available in Part Store.
Static noise and focus issues are related to fly back.
Posted on Oct 03, 2008
When I turn on my rear projection tv the picture is fine, then all of a sudden it goes blurry, after about 45min you turn it off and then back on and the picture is fine. what could the problem be. the...
well if your tv was to be a normal tube tv, i could suggest to check your crt socket. in this case its projestion tv, so your are having three crt sockets. the main problem is with your main flyback transfomer. try to change the flyback and it should work back to normal. other way to test is try to adjust your transfomers focus, if it is adjusted, and goes blury again, then you need to change it,...and try to re-service the board...best luck
Oct 19, 2009 | Philips Magnavox 51MP392H Rear Projection...
My tv is blurry. how do i get it to clear up? I
CRT tv's have a FOCUS adjustment on the flyback transformer. There may also be a "screen" adjustment on it, but you DO NOT want to turn that one.
You would have to open the tv, and take an INSULATED TOOL and turn the little adjustment labeled FOCUS or F on the flyback transformer, which is the large (usually black) thing that makes the high voltage for the CRT. It can easily be found by tracing the large red wire that has a suction cup at the top of the tube in the back. This wire goes to the top of the flyback. the focus is usually on the side of the flyback.
IMPORTANT!!!!
You must be very careful when doing this. Use a mirror to see the front of the screen while adjusting, don't reach around! Since this is the part of the TV that has LETHAL voltages you must be VERY careful not to touch anything else, since this must be done with te set turned on and warmed up.
Jun 10, 2009 | Samsung Televison & Video
Kodak easyshare picutres are pink and a little blurry
This Sometimes can be a Problem with the Memory Card..............
Try using a diffrent memory card if u have One....if not try to take a Picture without the memory card and if that comes out fine that means the memory card has a Problem if that also has a Problem Contact the Manufacture............
Feb 12, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Blurry, purple cast to picture.
check the crt cap that is connected to your picture tube...it may be greenish inside...try to change the crt...and adjust the focus...
Sep 03, 2008 | Zenith Z25X22S 25" TV
Blurry screen
There is a focus adjustment inside on a part called the flyback transformer. It's located toward the back of the circuit board, and you'll know which part it is by the red cable going from it to a connection on the picture tube. The flyback generally has two small adjustment knobs on it. The focus knob is the upper one. Slightly turning this one way or the other may improve the focus a bit, but usually a sudden loss of focus means either the flyback or the picture tube has failed. Either of these is cause to treat yourself to a new monitor. You can buy 17-inch flat screens now for less than $150 at regular prices, and sometimes you'll catch a good sale at the office stores.
If you choose to try the focus adjustment, BE VERY CAREFUL!!
1) You have to remove the back of the monitor and work with the power on. Parts inside, especially the picture tube, can give you a very nasty shock AND EVEN KILL YOU.
2) Be very careful where you are putting your fingers when working on a live set. Make sure you have a safe grip on the adjustment knob first, THEN look at the screen while you adjust it. Don't go blindly reaching around.
Aug 31, 2008 | HP Compaq FS7600 17" CRT Monitor
RCA r56wh78 rear projection screen is blurry
if you have little knowledge about electronics, you have to open the back of your tv and adjust the focus adjustment located at the back of the flyback transformer the large black colored like hard plastic... and if it is still not working replace the CRT socket....
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No matter what Picture is blurry
there is a internal part called flyback transformer and on it has two controls, one is for focus. If that won't help the flyback would have to be replaced
Nov 17, 2007 | Zenith A32B86R 32" TV
Blurry picture
adjust the flyback focus of your tv
just look at the flyback and you can see there the focus and the adjusting for the screen.
thats only what i know at least maybe it can help =).
Sep 23, 2007 | Toshiba 57H83 57" Rear Projection HDTV
Dim and blurry
try adjusting the focus control located on the flyback of the tv. good luck
Jan 31, 2007 | GE 32GT740 32" TV
Picture is blurry
it sounds like the focus block or flyback is bad.sometimes you can put nail polish on the adjustments controls to make it stay.usually they are marked from the factory with white marks check and see if they are aligned.but be sure somebody with tech-skills help you.the flyback usually has a screen & focus control.(the big red wire to the tubes or block)
Oct 06, 2006 | Zenith Z46Z83D 46" Rear Projection...
Toshiba 32HF73 32" TV Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
