Have a small GE AC/DC Remote TV/FM radio that I love -- The other day, it just stopped working -- Does this TV have a fuse that is replaceable???
This is an old (approximately 12 - 15 years old ) 9-10-inch TV that I use on my desk. Picture and everything were great and then while watching it, it just stopped working as if the electric cord was pulled. We did have a thunder storm earlier that day that shut down the electicity, but it was working after that. It seemed as if a fuse blew and I can't find any information on this TV to find out if it even has one or where it is. Please help. THANK YOU. E-mail at LinMur@opexonline.com
    Scholar:
  • 142 Answers
You can get a service manual at samswebsite.com. Good luck!@
barneyluc
Posted on Oct 03, 2008
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
Why did the ac power quit working on my pr-d7? the dc still works fine.
there is a diode D301 must be opened, replace it should be ok, but have to check your AC adaptor in advance.
Nov 17, 2014 | Sangean PR-D7 Digital Rechargeable AM/FM...
Transformer AC 9 Volt, battery 4x 1.5 Volt DC. On
first is no i would not recommend feeding the 9 volt dc through the actual 9 volt ac it may damage the bridge rectifier that converts the ac to dc
Aug 08, 2013 | Sangean ATS 909 AM/FM/SW Radio
Change radio from am to fm
To change between AM and FM push the BAND RADIO ON button on the radio or the remote. Here is a link that will allow you to view or print the manual for your radio:
http://static.fixya.com/Manuals/G/GE/75295_Clck_R_4FB4DC9750E55A3910C4BE1CD2294289.pdf
Nov 30, 2009 | GE 7-5295 Undercounter DC /Radio Combo -...
Philips SAA7130 TV Tuner/FM Radio/Video PCI remote stopped working
PLEASE THE SEND THE TV TUNER CARD DRIVERS I AM LOST THE TV TUNER CD
May 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
Does not accept power from mains & does not charge ... only stereo works from battery. My only guess is that the charger assembly may need to be replaced. Is there anything I can do to fix this without...
when you plug it in to ac volt did you hear any single click sound from the radio?. if no it could be just the fuse problem only. remimder radio has 2 fuses 1 for ac & 1 fuse for dc operation..fuse rating not the same.
Jul 04, 2008 | Dewalt DC011 AM/FM Radio
Ge model 46gw945
NEED SOME TECH EXPERIENCE ON THIS--- UNPLUG THE TV,,,I REPEAT ,UN PLUG THE TV FROM AC---TAKE THE BACK OFF--CHASE
THE CORD THAT GOES INTO TV AND YOU SHOULD SEE A SMALL 5 AMP FUSE IN A HOLDER,,CHECK TO SEE IS IT;S BLOWN--IF SO ,,REPLACE IT WITH"""THE SAME FUSE""""""""""" ,,AFTER REPLACING --REPLACE BACK OF SET ,,PLUG IN AND TURN POWER ON,,IF IT STILL DOES NOT COME ON --CALL A SERVICER,,,,,IF IT WORKS ,,,,,,,,,,,,,YOU OWE ME 35.00--HA!!!!!!!!!1
Feb 09, 2008 | GE 46GW945 46" Rear Projection Television
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Televison & Video Logo
Top Televison & Video Experts
