Drivers I am trying to hook up a zune that a friend gave me and I get a message saying that the drivers are not found on my computer. How can I install the needed drivers for my zune?
    Scholar:
  • 125 Answers
Hey there seems that i have an easy solution to your problem here is how you get the drivers
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Microsoft-MP3-Zune-Digital-Media-Player-Driver-14.shtml
download the drivers install them on your computer and you are set. Let me know how that turns out.
Posted on Oct 03, 2008
My zune kills my laptop!
You need to either uninstall and reinstall the Zune software, test the usb ports with other devices to see if they kill the laptop and update the usb drivers if it does, or restore your computer, since it could either be a corrupted Zune driver, corrupted USB driver, or an issue with your operating system.
Oct 05, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune software won't recognize Zune when plugged in
Go to Device Manager by right-clicking on My Computer > Properties. Depending on what version of Windows you are using you will see Device Manager somewhere (might have to switch tabs).
With your Zune plugged in, you should see it under Portable Devices or Disk Drives or something similar (look under anything that could describe the Zune).
Next there are a few things you can try:
1) If the Zune is not installed (has a yellow ! next to it), right click and update driver, then tell it you want to specify where to look, and look in Program Files\Zune\Drivers\Zune\ . The file Zune.inf should be in there, that's the Zune driver.
2) If the Zune is installed, right click and select uninstall, then reinstall the driver I specified in step 1.
That should work, if it doesn't right click on the Zune in Device Manager, go to Properties and tell us if there are any error codes or if it says the device is working properly.
Jul 16, 2009 | Sony PlayStation Portable (PSP) Console
My 4 gb Zune was charging and now it wont come back on!
I found this on the Zune technical support (if this does help, be sure to rate my solution please):
Your Zune device is not detected by your computer or the Zune software
View products that this article applies to.
SYMPTOMS
When you try to use Zune Software, you experience one or more of the following symptoms:
• The Zune device is not detected by the computer.
• The Zune device is not detected by Zune Software. In this case, when you pause on the device icon in the lower-left corner, you receive the following error message:
No Zune device connected
• If you restored the Zune device software, the following messages are displayed on the Zune device:
Connect Zune to your PC
On your PC, open the Zune software and restore the Zune device firmware
THINGS TO TRY
To resolve this issue, follow these steps:1. Update the Zune software on the computer. To do this, click settings, click software, click GENERAL, and then click CHECK FOR UPDATES.
If the issue is still not resolved, go to the next step.
2. Restart the Zune device.
To do this, follow these steps: a. Set the Hold switch to the unlocked position.
b. Press and hold the Back button as you press the top of the Zune pad.
When the Zune device begins to restart, release the buttons.
3. Disconnect the Zune device from the computer, restart the computer, and then reconnect the Zune device.
4. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
5. When you connect the Zune Sync Cable to the connector port of the Zune device, make sure that both ends of the sync cable click into position. Additionally, make sure that the sync cable is not connected to the device at an angle.
6. Connect only one Zune device at a time. If you already have a Zune device connected to the computer, any other Zune that you try to connect will not be detected by the Zune software. Disconnect any additional Zune devices, and then try to connect again.
7. If a full-screen battery image appears when you connect the device to the computer, you must let the device charge for several minutes before the device will start and be detected by the computer.
For more information about how to charge a Zune device, click the following article number to view the article in the Microsoft Knowledge Base:
927348 (http://support.microsoft.com/kb/927348/) How to charge the battery in your Zune device
8. If you are using Windows Vista, install the Cumulative update rollup for USB core components in Windows Vista software update. This update resolves some reliability issues in the USB core components in Windows Vista. You will achieve better reliability in various scenarios by installing this update.
For more information about this update, click the following article number to view the article in the Microsoft Knowledge Base:
941600 (http://support.microsoft.com/kb/941600/) Cumulative update rollup for USB core components in Windows Vista
If you are not using Windows Vista, or if the issue is still not resolved, go to the next step.
9. Examine Windows Device Manager. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
b. Click Device Manager. Zune should be listed under Portable Devices.
Note If the device was installed incorrectly, Zune may be listed together with a yellow exclamation mark (!). Or, it may be listed under Other devices as USB Device.
Double-click Zune, and then click the Driver tab. The current version of the driver that is installed should be 2.3.1035.0.
If Windows Device Manager indicates a device problem, or if the version of the driver that is installed is not the current version, you must update the driver. To do this, follow these steps: 1. Right-click Zune or USB Device, and then click Properties.
2. Click the Driver tab, and then click Update Driver.
3. Click Search automatically for updated driver software.
4. Click Install if you are prompted to do this.
5. After the driver installation is complete, click Close.
If Windows Device Manager found the drivers, click Close. If you want to locate the drivers manually, follow these steps:1. In the Zune Properties dialog box, click Update Driver.
2. Click Browse my computer for driver software.
3. Click Browse, locate the \Program Files\Zune\Drivers folder, and then click OK.
4. Click Next.
5. Click Install if you are prompted to do this.
6. After the driver installation is complete, click Close, and then click Close again.
10. Examine the computer for conflicts that involve the USB host controller or the root hub. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
c. Expand Universal Serial Bus controllers.
d. Verify that no errors appear in the list of USB devices. A yellow exclamation point or a red "X" next to a device indicates errors. If any errors appear, contact the manufacturer of your computer.
For more information about how to troubleshoot conflicts in Device Manager, click the following article number to view the article in the Microsoft Knowledge Base:
310126 (http://support.microsoft.com/kb/310126/) Troubleshooting device conflicts with Device Manager
11. Try using a different Zune Sync Cable.
Apr 10, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
HELP!!!!!
Does it require drivers ??
If it was working before then try the following
Click start, right click my computer and click properties
Choose device manager,
Right click on the list and choose scan for hardware changes ,, it should show up..
If it was not working before
The device should have come with a driver cd..
Install the necessary drivers off the cd ( the compuer should do it once the cd is inserted the auto run app will start and select install drivers)
If you dont have the cd log on the manufactures web sit and you should find the drivers for you particular model there along with the other applications you will need.
Jul 09, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune installation
shens - you must have an internet connection; also, make sure the lock is disengaged and that your computer has a compatible operating system
star - Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
for more help, go to:
http://www.zune.net/en-us/support/usersguide/default.htm
Jun 15, 2008 | Microsoft Zune JS8-00001 Digital Media...
My computer wont recognize my 30gb black zune
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 12, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
30 gb zune can't get into program
May 07, 2008 | Microsoft Zune JS8-00001 Digital Media...
30gb zune install
Apr 21, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 30GB black
if it says "contact support" restoring it will not work anymore. listen to the zune's hard drive. if it spins but makes a repeittive noise, the HDD is broken. if it doesn't spin at all either the hard drive of the motherboard may be broken. on the 80gb zune it's usually the logic board or the hard drive cable that causes this. there is a zune repair tutorial online gives you an idea on how to do the replacement yourself. parts are on ebay.
Dec 17, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
PC will not detect my zune.
Hey!! I just fixed mine! I had recently installed drivers for a PS3 controller, and for some reason those were conflicting with the Zune.
To fix it, I went to add/remove programs, and then removed the libusb program, that fixed it instantly! Good luck!
Dec 04, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
951 people viewed this question
 Grubhead
Grubhead
