Question about Sony KP-57WS500 57" Rear Projection Television
Color distortion and arched picture
When turned on my television has color distortion where the three colors separate and the picture on the screen is arched. please help! COLOR DISTORTED PICTURE ARCHED.
  • 3 more comments
  • Anonymous Oct 14, 2008
    color distortion and arched picture problem
  • joseph_xuan Oct 30, 2008
    Hello to all & to "Welcomejee", My name is Joseph and I seem to have a very similar problem, my model however is an KP-51WS500 (im guessing smaller screen size) the Time will blink either 4 times or 6 times but under the self test it shows no errors ever recorded. I would say close to half of my screen "left" side is arched a little and distorted green and red not alignled. I hope someone is able to offer help with this problem. Here are some pictures and thank you very much in advance.
    [IMGhttp://i145.photobucket.com/albums/r204/...[/IMG]
  • daver661 Oct 30, 2008
    i have a sony kp57ws500 and the center of the picture is ok but the right and left sides the color is mis-aligned. the red, green, blue do not line up so there is a shadow. this is making the picture very blurry.
  • Anonymous Dec 13, 2008
  • jme959 Dec 14, 2008
    I have the same problem with my Sony KP-57WS500 57 in. Rear Projection Television. I had it fixed back in April for 498.00, and it is doing the same thing again. I was told it was convergence and they replaced a part and it worked fine for about 7 months and then one night watching a movie it went out again.
  • 10,594 Answers
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Posted on Oct 03, 2008
Hi ,,my problem is one day turning on the tv and it turns itself off ..when i got it back on the color was distorted and theres a color arch thru the picture ...we get a picture but its not aligned ..and...
This would be called a convergence defect. IT is not a real bad repair but it will have to be done by an authorized RCA repair shop. The alignment takes a jig called a chipper checker. Call around your area. WE charge about 250.00 to do this in columbus GA. THat should give you a starting point
Please leave feedback
Feb 21, 2011 | RCA P52926 52" Rear Projection Television
The picture suddenly became distorted with three archs at the top of the screen (red, blue & green I think). Is this a bulb that burnt out that I can replace?
no bulb the fact you have those three colors tell all tubes are working.... this may be a convergence issue sometimes i have seen this. check to see if you have the convergence option in your menu under setup. distorted in what way
Oct 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors don't line up, and screen is distorted on a sony KP43HT20
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 08, 2009 | Sony KP-43HT20 43" Rear Projection...
Yellow arch on bottom left of screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 30, 2009 | Toshiba 43H70 43" Rear Projection...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Jun 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Color Separation and Arched Picture
Please call a repair center. This is something you cannot repair your-self. It's usually around $200-400 for the repair depending on who does it.
May 07, 2008 | Sony KP-57WS500 57" Rear Projection...
need to replace both convergence ICs numbers STK392-560 you can get replacements with free instalation instructions with pics so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Apr 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
441 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
