Question about Konica Minolta Office Equipment & Supplies
Konica 7030 will not power on
Will not power on. I have checked the power cord and the main switch and both are OK. The relays are not tripped.
  • Konica Minolta Expert
  • 1,326 Answers
How about the wall outlet? Try another one or plug something else in to test the outlet. Also, look on the back of the copier by the power cord in put for a breaker that may be triped...
Posted on Oct 03, 2008
Konica bizhub 283 photocopier error code c9401
FIRST, if this code comes back. Have a technician look at it the exposure lamp the bright light under the glass is bad or the board controlling it.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Mar 22, 2017 | Konica Minolta Konica Bizhub 283 Copier,...
Unit just stopped working. Power is being supplied to the unit.
There can be a trip switch or timer that has cut off, remove power and power after an hour. If the AC does not power on then start from the power cord to the panel, if there is control panel the power to the unit could have failed and so the functions are dead . Also check the main relay to the compressor.
Jul 05, 2011 | Heating & Cooling
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
When turned after a time it trips main fuseboard
hello mam
please check the following
1.short circuted power cord this can be checked by disconnecting the power cord from the dryer and switch on the mains.
2.heating element is defective this can be checked externally by dismanteling by the druer.
3.dryer motor is defective this can be checked externally by dismanteling from the dryer.
Sep 21, 2009 | Dryers
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
Konica 7030 copier: works good exept no power on ADF
In this particular machine it is very likely that the PSU (Power Supply Unit) has blown. You could also try another power cord/power socket.
Jan 13, 2009 | Office Equipment & Supplies
My whirlpool refrigerator trips the main power
Pankaj, Do you have a ohm meter? Sounds like you have something shorting back. First take the meter to the cord. On the end of the cord, you should show no continuity from each male prong to the ground prong on the cord itself. If you show continuity, you have something shorting back. Then I would start with the compressor, Unplug the wires going to the overload and relay, make sure the units unpluged and meter the cord again. If it's ok, then the problem is in the overload and relay. Start there and let me know, if it still showing a short, then we will have to go to the controls, heater, and repeat the process until you find the culprit. Catriver.
Jun 09, 2008 | Refrigerators
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica 7030
The problem is a fixing unit abnormality code, could be caused by a bad temp. sensor, build up on sensor or maybe the machine experienced a voltage spike. Power the machine off using main power switch and sub power switch, unplug IP (Image Processor) and any phone lines that may be hooked up.
1) turn on power (both) sub and main while holding down the 2 and 5 buttons on op. panel. a screen will come up.
2) Select 1) software switch setting
3) using the arrows on the screen select dip switch 3-1
4) touch the off key on the LCD to change the data to 0.
5) press return and power equipment off and back on again.
Good luck.
Jan 15, 2008 | Office Equipment & Supplies
74 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
