Ask to formatt - Audio Players & Recorders
    Genius:
  • 3,422 Answers
HI,
To format your player simply connect it to the PC with the USB cable and then go to MY computer and you will see External drive Icon beside your dive just right click on it and select format.
Posted on Oct 02, 2008
  • Priya darshan Oct 02, 2008
    IF you need anymore help let me know.
My HP M2727nfs prints blank pages. Even demo page / reports are blank. NO errors on display. Paper gets warm, so fuser works. New cartridge doesn't help. Neither cold reset. What can this be?
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Sep 14, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp M2727 goes into low power sleep mode and can only recover by cycling power
This is a problem with the formatter board, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years. Al
Jun 30, 2010 | HP Laserjet M2727nf Multifunction Printer
Mine keeps initializing by itself randomly..then freezes up.
Al
May 20, 2010 | HP LaserJet M1522nf Multifunction Printer...
All lights comes on and nothing show on the screen when switch on
Seems like a comunication problem betwen the formatter PCB and the attached parts on it tike jet direct card, memory chip.
With the printer turned off, remove the formatter plastic and metal covers, start removing the jet direct card first, after removed turn the printer on and see if the printer starts normaly....if dont....turn it off and reinstall the jet direct card and do the same with the rest of attachments in the formatter board....if none solve the problem...then probably you have to replace the formatter board.
Some times the contacts betwen the formatter and the memory chip get dirty or contaminated with electrostatic......try cleaning this contacts with contact cleaning solutions or use isopropilic alcohol and a cotton swab...make sure not to use a lot or make sure that is totaly dry before to reinstall the chip(s)...and try again.
The formatter board you can buy it with different vendors but I recomend The Printer Works at 1-800-832-1400 or www.printerparts.com and ask for a refurbished formatter....is cheaper and they work very well at this company.
I hope this can solve your problem
Jan 13, 2010 | HP LaserJet 4250n Printer
M2727 goes to sleep after a day or so and cannot be awoken, except by cycling power. After two days or so, the display is even out and printer looks as if it is unplugged. No button on front control panel...
Nov 23, 2009 | HP M2727NF Laserjet Printer
Low memory. won't send or receive fax. 49 error message.
Oct 16, 2009 | HP LaserJet M1522n MultiFunction Printer
Door is closed but it says door open and light flashes
This could be a problem with the formatter board, try doing a nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years. Al
Sep 25, 2009 | HP LaserJet M1522nf Multifunction Printer...
N73 security code
standard security code when you format your nokia phones is 12345!
Aug 15, 2008 | Nokia N73 Cellular Phone
Operating system installtion problem
First try to replace you memory module(s) (RAM) should you be using more than one ensure that they are both of the same frequency then when installing windows xp at the setup menu where it asks about partitions delete any present partition and formatt a new partition with the NTFS (do not use the quick formatt, use the more thorough formatt). thereafter you windows will be installed and you shouldnt have any further problems.
Jun 07, 2008 | Mercury PVCLE266 Motherboard
 Grubhead
Grubhead
