Question about Magellan Roadmate 760 GPS Receiver
Roadmate 760 Password Reset
Hello, I have just inherited a Magellan Roadmate 760 as it was in my friends garage and needed to be fixed. After repairing the power issues, the screen comes on and has three different users, all password locked. How can I reset the system to forget the passwords or get around the passwords?
    Novelist:
    Scholar:
  • 86 Answers
Dark,
Although it has been some time now since I've worked on these, I beLIEve if you plug the unit into your computer you can explore the files and there should be a file called password or pwd or.. something along those lines.. all you have to do is delete the file and it will work. It was surprisingly easy I remember that much. If this doesn't work, play/look around with the files in the unit, and as a precaution I would copy the file over to your computer prior to deleting just in case.
-Daniel
Posted on Nov 21, 2008
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
Hung up magellan roadmate 760
You'll need to call customer service at 866-868-2259.
They should be able to tell you how to do an "emergency reboot". You also need to make sure you have the latest "firmware" before installing any updates.
Dec 15, 2007 | Magellan Roadmate 760 GPS Receiver
Stopped connecting to satellite
check battery condition also go into set up and see that the baud rate and port are set correctlyb in accordance with the manual.
Please rate my help++++Thanks for using FIXYA
May 20, 2009 | Magellan Roadmate 760 GPS Receiver
I'm trying to update a Magellan map update on my 760
plke1691
I think your problem is that you are using XP with SP 3, you cannot use anything more than XP SP2, so find yourself a friend that have an older operating system and update it. I bet you will not have any problem
Auto Nav 2000 aka GPS4ME
Apr 30, 2009 | Magellan GPS
I need an upgrade for my magellan Roadmate 760
You can download an upgrade for this unit from the Magellan website for free. Maps can be upgraded but they cost about $80, and that doesn't seem worth it to me. See if that works for you.
Dec 13, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 does not find satellites
I recently i had the same issue. Open the four screws from back. remove the back cover carefully (tahe care of the attached cables).
check the atena wire connection (gray thin wire). both the ends should be seated firmly.
in my case, soldering at one end was broken. had to resolder. its working now.
Nov 04, 2008 | Magellan Roadmate 760 GPS Receiver
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Power suply Loose contact
only way to get that fixed would be to contact Magellan to get it fixed or if your is the kind with the power dock on the back you could order that part from tigerdirect.com
Oct 24, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
237 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
