Question about Toshiba TLP 260 Multimedia Projector
My Toshiba TLP-260 image color is fade
My Toshiba TLP-260 projector image color is fade. I called technician to fix. He said the color transition part is brocken and will not find this part. Where can I buy it?
  • 279 Answers
SOURCE: Toshiba TLP S10 Projector
http://www.toshiba.de/projektoren/resources/pdf/manual_s10e.pdf That link will take you to the owner's manual. It should answer whatever questions you have.
Posted on Aug 28, 2007
SOURCE: Projection Problem with Toshiba TLP 261
The projector uses a polarising filter, in between the lamp lenses and the LCD panels. Due to overheating, it's possible for the filter to become tarnished - it's only a thin plastic film bonded to glass slide. Replacing the polarising filter is a complex job, requiring complete disassembly of the projector - but can be done. Use replacement polarising film from any optical camera supplier.
Posted on Sep 02, 2007
Marrie
  • 563 Answers
SOURCE: SMALL ICON APPEARS ON THE SCREEN (TOP L/HAND CORNER)
Hi there
Have you tried pressing the Menu button when this happens ?
Posted on Mar 26, 2008
projdoc
  • 2237 Answers
SOURCE: Toshiba LCD model#TLP-T60M. Projects images but
reset the settings to factory default. then make sure that the input matches the signal and that the cables are working. if you still have a problem, and the entire screen (including the initial toshiba screen) is entirely green tinted, you may have a main board issue.
Posted on Nov 11, 2009
projdoc
  • 2237 Answers
SOURCE: projector Toshiba TLP-T50 cannot display
if the lamp is bad, replace it. if not, replace the ballast.
Posted on Dec 23, 2009
The screen color is distorted
Check your VGA cable, if they are constantly plugged in and out, a pin may be damaged. Also try wiggling the cable at each end, ie from the laptop and the computer, I have had problems with the VGA output on the laptop. If this doesn't correct the problem it will probably be a polarisor lens, if so it will probably cost more than a new replacement projector. I recently purchased NEC NP115 for just over £200.
Good luck
Aug 09, 2011 | Toshiba TLP 260 Multimedia Projector
I have a Toshiba TLP 260 Multimedia Projector --after a couple of minutes of being on the fan icon appears in upper left corner the projector will shut down indicator lights for the fan and on, goes red. ...
If all the fans are running and you are sure, than it sounds like you have a bad main control board. Double check that all the fans are running. If so you will need to replace the main controller, this is the board that the fans are plugged into.
Thanks the Projector Guy
Apr 21, 2010 | Toshiba TLP 260 Multimedia Projector
Just connected a laptop to TCP260 and can't view computer image. Do I need to install a driver on my laptop to run the projector?
Reboot your Laptop, while connected to the projector which has been turned on in advance. Otherwise, simultaneously press Fn + F5 for the command to to transfer to other monitor plugged in. Toggle and wait at least 1 minute everytime to allow the computer to stabilize
Feb 18, 2010 | Toshiba TLP 260 Multimedia Projector
I have a Toshiba TLP-S30 and lately the color balance of the projected image is way off. I've tried adjusting the color balance via the menu, but no improvement. Could this problem be fixed with a new...
reset the settings to factory default. sometimes the lamp will burn at a lower temp at the end of it's life and emits a different color. might be the lamp or the ballast. if all else fails, replace the main board.
Oct 18, 2009 | Toshiba TLP S30 Multimedia Projector
Toshiba with Colour fail , red colour
the filter lense of color red had discolored
Feb 04, 2009 | Toshiba TLP 260 Multimedia Projector
Showing to of the same thing twice and colors
The projector has one or more "burnt" polarizers, more than likely.
They are replaceable, but expensive if you buy them from the manufacturer.
Look on Google for "burnt polarizer".
It's not the easiest job, but at least they're replaceable.
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Toshiba TLP 260 Multimedia Projector Logo
87 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
