Question about Xerox WorkCentre XK50cx InkJet Printer
Printing problems: Using the print command on my computer requesting two copies of a report results in the XK50cx printing only one copy. How can I get it to print multiple copies on command? Second problem is using the print command on my computer requesting two sided printing of a report results in the XK50cx printing only on one side of the sheet of paper. How can I get it to print on both sides of the paper?
  • 2072 Answers
SOURCE: Phaser 7300n Printing on Double Sided Glossy Paper
At first I didn't think the paper was the problem, but I looked up the specs on it and is seems to be a paper designed for an offset press.
I suspect after reading the information on the paper that the coating is not designed for the high temperatures of a laser printiers fuser heat of over 350 degrees.
I do suspect the paper is the issue.
sounds like you are melting the coating.
Posted on Dec 31, 2007
freetek
  • 5568 Answers
SOURCE: My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Posted on Sep 23, 2008
  • 2072 Answers
SOURCE: Second side printing driver
Yep. Go to Xerox.com , click on support and drivers. Then in the search box enter 8560, click the search button, then you will see in red letters a few selections. Click Downloads and Drivers, Once there you will see several options. I would recommend Post Script driver for that product. But there is a Global, a web based, and a standard PS as well as PCL drivers , a driver install progeam and also there should be the most recent firmware update for that product. If you happen to be running an older OS, use a Legacy driver.
Posted on Oct 23, 2008
c_robertson
  • 123 Answers
SOURCE: prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Posted on Apr 29, 2009
  • 25 Answers
SOURCE: DC 1250 Paper Jam when printing few copies
Well that problem is because there is not enought oil on the fuser roll. The problem is the oil pump. change it before make one irreversible damage to the fuser or pressure rolls. Do a full maintenance of the fuser module.
Posted on Jun 06, 2009
How do I move the printer from copy to print mode?
Copy Mode is done from the control panel of the printer. Printing is done from the computer and whatever program you are using to print like MS Word - Print command will over ride the printer.
When printing a web page press CTRL+P and then Print.
Let Kakima and I know the make and model and we will find your manual. They are all available online.
Reply via COMMENT below either post and we will get a notification to help you.
Nov 30, 2016 | PRINTER Office Equipment & Supplies
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
Canon mf5750 prints blank pages
Can anyone tell me where the formatter is located?
Is it part of the mainboard of the mf5750?
I read somewhere, that the formatter is responsible, if standard printing works (status reports etc), but normal printing tasks do not.
Really no solution guys? I cannot believe this.
Thanks for any advice.
Joe
May 30, 2012 | Canon LaserBase MF5750 All-In-One Printer
Printer does not respond to "Copy" command
Press and hold the Setup button, and then press Options (or Copy Options ).
It will bypass the alignment.
Apr 09, 2010 | HP PSC 2175 All-In-One InkJet Printer
How to set a printer to print only 1 copy no matter what # is put
You cannot do it -- when you request '3' copies, the computer sends 3 times as much text & commands to the printer. So, the printer cannot tell when the 2nd and 3rd copy begins.
Sep 14, 2009 | HP LaserJet 1200 Printer
Canon 3200 only prints one copy from computer
You will probably have to delete and reinstall the printer. I have had features quit working on my 3200 and on my 2 105's. A work-around is to print to your mailbox and then print your job from there.
I tend to have problems from Microsoft products more than adobe.
Are you printing through a fiery or just through the print board on your copier. If you are using a fiery, then you can resend the job from the command work station (a free download if you are using the fiery).
May 20, 2009 | Canon imageRUNNER C3200 Copier
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
Apr 28, 2009 | Office Equipment & Supplies
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Sharp AR-M160 , printing problem with OS: Windows 2000
Is the cable and the computer the same? sounds to me as if your not using a bidirectional cable
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Xerox WorkCentre XK50cx InkJet Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
