Question about Ingersoll Rand Ingersollrand Dual Action Air Sander - 6" Dia, 4 CFM 10,000 Rpm, Model - 311A
How do i use this thing
Is the sanding pad supposed to be threaded so that it screws into the sander itself? if not how am i suppose to connect the pad, i have been looking at this for an hour and still cant figure it out.
    New Friend:
  • 55 Answers
Yes it should screw on and the sanding pads should either be sticky or velcro
Posted on Dec 04, 2008
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
How do I replace the fan assembly cannot hold armature assembly to get inner bearing out without damaging armature assembly
If you are replacing the fan assembly because the internal thread that holds the rubber/velcro pad has stripped, there might be an alternative.
I had the same problem with my PEX 12AE, which I believe is a similar sander. I found that the hole is threaded a good bit deeper than the screw, so I got a longer screw and so far it's holding ok. If/when that fails, I might try repairing the thread with an insert.
Curious to know how you managed with your sander.
Feb 09, 2012 | Bosch 3107DVS Electric Sanders & Polishers
I replaced the rubber sanding pad but the screw keeps backing out during operation.
Some pads come with a new screw that has loc-tite on them. If you used the old screw when you put the new pad on, the loc-tite was probably dry and flaking off. Put a small drop of loc-tite on the threads, snug it down and let it sit over night and it won't come out anymore.
Sep 15, 2010 | Bosch 3107DVS Electric Sanders & Polishers
Pad siezes up
Use some loctite thread locker on them.
Jan 17, 2010 | Makita BO5010 5" Random Orbit Sander
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
I can't get the sandpaper to stay on the pad.
It sounds like you need to replace the backing pad on the sander. Over time the velcro (hook & Loop) on the backing pad will loose its stick. A Bosch service cneter can supply you with a new one, just let them know which model you have. If its an adhesive back sanding pad the same thing applys just get a new one. Hope this helps
Apr 11, 2009 | Bosch Power Tools Sanders Orbital Sanders
Hook and loop pad
Try the amazon, here: Amazon com Makita hoop loop. Wish you best of luck. Cheers
Fred
Mar 25, 2009 | Makita BO5010 5" Random Orbit Sander
Hand sander stops spinning once placed on item to be sanded
This sander has a brake pad that is supposed to stop the rotation when the sander is not actually in use. It sounds like it's malfunctioning.
The only other thing I can think could be a cause of what you describe is an improperly assembled sanding base. Have you changed out the base, and if so, were you sure to properly align the replaced base on the machine before you tightened the allen screw?
If you're not comfortable disassembling a tool that is still under warranty ( I think it's two years for that one), I would recommend finding a Dewalt service center and taking it in for a factory service call.
Mar 24, 2009 | Black & Decker Black And Decker Cyclone 4...
Changing the rubber pad on the Bosch PEX 12 AE
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 01, 2009 | Bosch Power Tools Sanders Orbital Sanders
7336 orbital sander
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
Sep 10, 2008 | Porter Cable 7336 6 Inch Variable Speed...
Ingersoll Rand Ingersollrand Dual Action Air Sander - 6" Dia, 4 CFM 10,000 Rpm, Model - 311A Logo
180 people viewed this question
Top Ingersoll Tools & Hardware - Others Experts
Mike
Eddie Tucker
Level 1 Expert
Lawrence Oravetz
Are you an Ingersoll Tool and Hardware - Other Expert? Answer questions, earn points and help others
