I have a PDP 5071 that I moved and now it has a white line about 2 inches wide from top to bottom? is there a reset I need to do? Thanks
Hello
Just do a factory reset to all option. Just go to its user manual page number [[64]. All the details are described there. OK.
The plasma display automatically selects and appropriate screen size when viceo signals are received from a connected HDMI equipment.. To activate this function enter inot its 'Adjustments and Settings' window, Press "HOME MENU". Seelct OPTION [UP/DN] then pres Enter. Select 'Auto Size' [UP/DN] then press Enter. Select 'On' [up/DN] then press Enter.
This adjustment must solve the proble to your Pioneer Plasma TV.
Go straight to the signal board. I have not personally repaired this TV. But I would investigate the signal board. It will have all the RCA jacks and RF connections. TheTVv seems to power up fine, so the power supply is good. As with an earlier comment, I would check all connections inside the TV. Before any attempt to pull the board out, you should always be sure the connections are are good and secure. Most problems are corrected here. If you need more info, I'll be here. Thanks for asking. Sincerely, Matt of Martins TV.
Since the fault has appeared after the TV was moved it is possible that there was some damage on the board or an alignment issue on the display section connectors. If you are able to shut down and remove back, press down all the connectors, remove and reset. check for any damage on the rear while it was transported , is so look out for any break.Other wise it is possible that there are errors within the display drivers for the noise pattern.Take help and consensus from Pioneer support .
The picture is fine I have the HDMI connected thru cable. The line is to the right of the center an about 2 inches wide, whatever mode or input I select it is still there
Thanks, I have the operating manual and the service manual and I cannot find anything on a factory reset. Is there a differnt term I should be looking for, I looked on page 64 (60-67) and found non factory resets
I was able to google the reset and I tried it...it still has a white liine when the picture is on, anyone have any other ideas?
I now have removed the cover and confirmed all ribbon and other connections are tight, I reassembled and reset the unit, still have white line. Is there any other tests or do I have to order a new component?
HI,
I tried to reset the screen size and it will not allow me to change the Auto Size (changes are not allowed under this setting) how can I unlock this setting?
