Question about Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash dishwasher control lock light flashing
I have an older model Kenmore ultra wash dishwasher model #15805890. The control lock light is flashing. No buttons are working. The dishwasher does not turn on. Any solutions?
  • 8 more comments
  • erwash Oct 22, 2008
    I have this problem, except that when I hold down the aiir-dry (unlock) button, it doesn't work. The 'lock' light just keeps on flashing, and I can't get the controls working.
  • Anonymous Nov 10, 2008
    LOCK LIGHT ON MACHINE WILL NOT GO OFF MACINE WILL NOT START
  • nhp1 Nov 23, 2008
    The lock on button is flashing and the "no heat dry wont make it go out.I've tried several times .
  • mcalhoun77 Dec 04, 2008
    The red light is flashing and pressing and holding the "no heat dry" unlock button is not doing the trick. Something else??? Please help I need my dishwasher back.
  • jlhnblh Feb 04, 2009
    My dish washer is flashing the lock on light and no buttons will work and it wont run.
  • Anonymous May 18, 2009
    I followed your advice and it worked. Thanks so much!
  • bfranklin Jan 23, 2013
    I had the same problem today and jiggled the handled from open to closed position several times and that worked.
  • M Neff May 15, 2013
    Thank you1 This worked for me! My airdry button is called "No Heat Dry" and I held it for 10-20 seconds and it released the control lock and I was able to start dishwasher again.
  • Anonymous Mar 19, 2014
    kenmore model 6651779990
    kenmore model 66517779990
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Posted on Dec 13, 2010
  • karenkeiller
    karenkeiller Apr 10, 2012
    My button is called NoHeat Dry, but the solution worked, thanks!!!!
Had this issue with our Ultra Wash Dishwasher. We've had it 12 years with no problems. Tried the holding different buttons for 4-6 seconds and sequential buttons with no results. Tried cutting power off and then on. No luck.
A solution on another site gave me the idea to disassemble the inside panel of the door (three screws on the sides and 2 at the latch) to lift it from the front, then lifted the black cover off (trigger points at left and right sides) the electrical area to access the door latch assembly. I jiggled that loose from the door to take a look and it was a bit sticky. Instead of using an air compressor, I dipped a soft bristle toothbrush in rubbing alcohol and liberally cleaned all moving parts and crevices. Hold it over a dish to catch the drips. I wiped it dry with a paper towel real good, blew a little over it to help evaporate the alcohol, then began to put it all back together.
As I was assembling it back, I took notice of how (at the top center on the box side) the metal tab will slide up the black plastic bit and snap down to engage the mechanism (white plastic) that pops the handle as you close the door. It is entirely possible that the tension was not enough to snap it far enough down. I adjusted the tab ever so slightly down. We waited a little longer before restoring the power, just to be certain it was completely dry. I am happy to report the light was no longer flashing! I am running a load of dishes as I am writing this note! Good Luck!!!
Posted on Sep 27, 2012
Thank you thank you everyone on here you made my day!!!! My old kenmore ultra wash lock button would only blink when i would press a button on it. It would not start at all. I pressed the "no heat" button and held it for about 5-6 seconds and walla my dishes are getting cleaned as i speak! thank you all for the good info.
Posted on Oct 08, 2012
Hi jabberr216,
I'm Harvey the Master Plumber.
Your question is: You have an older model Kenmore ultra wash dishwasher model #15805890. The control lock light is flashing. No buttons are working. The dishwasher does not turn on. Any solutions?
Sure! Someone must have activated the lock. It is next to either the 'air dry' or 'heated dry' button.
Press and hold that button till the lock light goes out. About 6 seconds. That's it. It turns on the same way.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 03, 2008
  • 2 more comments
  • jawagner81 Sep 09, 2012
    What can you do when that solution does not work?
  • b4mindcrime
    b4mindcrime Sep 12, 2012
    Thank you, thank you, thank you! I must have an even older model and I pushed the 'no heat dry' button and held it until the control lock light cleared. I was then able to start the wash cycle I wanted.
  • tucsonauctio
    tucsonauctio Sep 20, 2012
    Thank you so much for your information! It worked for me too.
  • wildonesmom
    wildonesmom Nov 27, 2012
    ive done this on mine and it still wont shut the lock off, any other ideas?
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore ultra wash 6651393 control lock light flashing
I would try turning the breaker off for 5 minutes to see if it will reset.
Jun 09, 2012 | Kenmore 15899 Built-in Dishwasher
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Kenmore Ultra Wash #15779
Probably would need the full model number but it looks like you control board is defective.
Sep 02, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwasher Problem
According to my ultra wash dishwasher you have to hold the no heat dry button for 4 seconds and that is how you lock and unlock the control panel
Jun 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher "lock on ' control wont turn off
Hold the control lock in for more than four seconds. See if that works.
Jul 25, 2007 | Kenmore 15762 Dishwasher
Kenmore 15899 Built-in Dishwasher Logo
5,975 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
