Question about Whirlpool Dishwashers
Soap dispenser will not open
Whirlpool mod# DU850DWGQ1. I took off inner door cover and replaced spring #3368999, the end of it had rusted off and broke. Replacing the spring did not fix the problem. The plastic mechanism inside the door seems to work properly when I manually operate it, but when I reassemble it the door still never opens. Help!!!
  • Wilbursdad Oct 04, 2008
    Can you be a little more specific here? What else is wrong with it? The spring cost @ $5. What else do you think is wrong with it? Not really looking to purchase a new dishwasher because the soap door won't open.
  • 750 Answers
Hello Wilbursdad
Welcome to fixya.
You said, Whirlpool mod# DU850DWGQ1. You took off inner door cover and replaced spring #3368999, the end of it had rusted off and broke. Replacing the spring did not fix the problem. The plastic mechanism inside the door seems to work properly when you manually operate it, but when you reassemble it the door still never opens. Help!!!
It appears to be a 2000 dishwasher model.
Unfortunately I did not meet you soon enough to stop you!!!!!!!!
If the springs rusted and broke, you are putting good money into bad.
I do not like to be the bearer of this news, but more than the springs are bad here!
You need to read this report that I just read before you sink your money into this model!
You may be spending all your time replacing parts soon!
______________________________________________________________________
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
My advice is cut your losses !
Sorry, but maybe you will get lucky if you repair it!
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Bless You
Huuum
Posted on Oct 03, 2008
  • Neil Golan
    Neil Golan Oct 04, 2008
    $5.00 for the spring was a great deal!!!!That was worth it!
    It sounds like the release switch in your soap disperser is malfunctioning and not releasing the Door.
    I had a dishwasher that the door was stuck closed once, and I only used the first soap container with the open door only.
    Right now I do not fill both soap cups in the dishwasher with soap either .
    I only use the one soap container and I am saving money on the soap cause it washes great anyway.
    Using both soap containers in the dishwasher is only needed if you have real dirty or dried, or baked on stuff.
    But yes I am using the one with the door and not that open one.
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dispenser lid doesn't open
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it
Oct 25, 2010 | Whirlpool Dishwashers
Soap dispenser door came off
First, look at the spring from sliding dispenser cover - it has 2 ends with loops - one end has a little "curve" in it; other end is "straight", no curve.
Sliding cover and lever of dispenser have little knobs for attaching the spring.
The loop of "curved" end has to be pushed and attached to sliding cover,
the loop of "straight" end has to be pushed and attached to lever of dispenser (the lever is blue color, other parts are gray).
After spring is attached to both - sliding cover and lever, push the cover first at upper groove, then at lower groove - It should slide easily.
May 26, 2009 | Gaggenau GI936-760 Dishwasher
Kenmore 16163 401 dishwasher
The dispenser flap should be spring loaded to spring open if the lock is released. If it doesn't spring open you should make sure that the spring is placed correctly on the hinge of the flap - if it doesn't spring open it won't get the detergent where it needs to go during the wash. We had the same thing.
Dec 17, 2008 | Kenmore 24 in. 16163 Built-in Dishwasher
Soap Dispensor does NOT open.
This is almost always a dispenser problem. The dispenser is replaced as a unit. you can reach it by removing the Phillips screws around the inside of the door and lifting up the inner door panel. The dispenser's frame is held in place with tiny (1/8 in or 5.5mm) screws.
Mar 11, 2008 | Dishwashers
Soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Jan 16, 2008 | Maytag 24 in. PDC3600A Built-in Dishwasher
Soap dispenser door not catching properly
THE INNER DOOR PANEL HAS TO BE DISASSEMBLED TO ACESS THE SOAP MECHANISM NO IT DOESNT JUST PULL OUT
Jan 16, 2008 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Maytage dishwasher soap dispenser not operating properly
I have an older (1990) Maytag dishwasher that had the same problem. In my case liquid dish soap had penetrated the seal and dried out causing the rotating cover shaft to freeze up.
Remove the door panel and then disconnect and remove the soap dispenser from the door. Make a diagram of the soap dispenser as you carefully disassemble it; there is a coil spring around the soap door axis. If you find a buildup on the door shaft or in the hole it rotates in or in the groove the door rides in, try removing the residue with a plastic scuffy pad after letting it soak in a lime scale remover (Lime Away) or some other cleaner. I think Jet Dry makes a dishwasher cleaner. Before you reassemble the dispenser, wipe a thin film of plumbers grease (available at Home Depot or Lowes) on the shaft.
If the door is free turning and doesn't appear to be bound up, then the problem may be with a heating element that expands when energized, allowing the door to open to the second soap compartment. An ohmmeter will be needed to test the thermal lock.
These jobs are fairly simple and should need only a Phillips screwdriver and a volt ohmmeter.
Happy Motoring!
Mar 06, 2007 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwashers Logo
329 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
