Question about IBM ThinkVision L170 17" LCD Monitor
Verticle lines on monitor
My monitor has four verticle lines running through the length of the screen. It appears as if the entire line is missing the image information. The spacing of the lines is irregular. Does anyone know how to correct this annoying problem?
  • mpgerrity Oct 03, 2008
    I thought so. Thank you for the reply.
    Champion:
  • 293 Answers
Hi...there,
Well... I hate to say, but you got a damaged panel. Thinking of replaced the panel... you can forget it.
Get a new one...it's will saved you the headached and $$$... Have a nice day!
Posted on Oct 03, 2008
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
Verticle lines/streaks down screen
The Display panel could be bad/damaged or the main board that controls every thing could be bad---parts for Dell equipment are known to be hard and sometimes impossible to find.
Dec 07, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
Verticle thin blue line on my IBM ThinkVision Monitor?
it may be a permanent damage on your monitor. i think it is unrecoverable.
Jul 16, 2017 | IBM ThinkVision L200p 20.1" LCD Monitor
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
May 05, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
There is a thin white verticle line on the monitor.
Open this link and make it full-screen. Watch the screen for 20 seconds or so to see if the line of lit (white) pixels remain.
If this line remains during this, and even when the the computer is first starting up, it is most likely a row of "lit" pixels caused by a faulty connection or circuit inside the display.
While you can sometimes rub the area of the screen near a single lit pixel, an entire line of them usually denotes a more complex problem that can only be fixed by having parts replaced by a technician
Note: Be sure all of your cable connections are securely fitted, and that the line is there no matter what is displayed on the display (especially at the boot screen before Windows loads).
Sep 20, 2009 | Samsung Computers & Internet
Verticle color lines on scanner bed and printout in photo mode
Hardware failure, nothing much can be done, just replace the scanner.
Aug 27, 2009 | Epson Expression 1640XL Graphic Arts...
What can cause a single red line to appear on my laptop LCD screen? It's a small/fine red line appear horizontally (left to right) It's NOT radio interference,back light,broken ribbon cable,or connector...
Thats a generic problem with LCD screens. Its more common in Mobile screens. Sorry, no there is no fix to it other than replacing the LCD itself. Just pray that it shall not grow because as and when the compressed gas from within the LCD will leak the line will be becoming broader and broader. It is caused by damage to the LCD corner Just a hit on side of LCD and a hairline crack for giving way to the encapsulated gas.
Jul 28, 2009 | Computers & Internet
Laptop lcd screen
that's not a firmware issue..your lcd is starting a slow decay to final unhappiness..
you can try the old driver downloader trick, but it's just a matter of time now.
Feb 21, 2008 | LG Flatron L1750S 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
227 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
