Question about HP Pavilion F1703 17" LCD Monitor
Back light goes out
Where can I buy a new backlight board?I have tried several things to fix it but with no luck ,so I think I will just get a new one.Any help would be appreciated.Thankyou,Branden.
  • 42 Answers
You probably need to resolder the two coils on the power/backlight pcb.
greetings Drikus
Posted on Oct 12, 2008
Vizio E480i-b2 LED TV loosing picture and sometimes shutting off
I don't think you had backlight issues like you thought you did as the set should have shut down the backlights totally as soon as it sensed over voltage or over current, I'd try a new main board and see if that fixes things up for you
Dec 09, 2017 | Vizio Televison & Video
Sound but no display
ok I have ran across this before.. First turn on the TV and go to a channel u know is good, with sound.. now turn off lights in the room.. or just darken the room.. next take a FLASHLIGHT and turn it on and shine it into the front of TV . If u see the images on the screen when moving the flashlight around. that is a good sign.. That usually means the Backlight board or boards are not working..with the TV on and in a darken room you should be able to see light coming through some of the Vent holes in the back cover, that means the Backlight board is working. from what u say I would bet on the backlight boards. pretty easy fix.. Unplug from the AC outlet. remove the back. Now be careful back there cause u can still get Zapped. I ALWAYS take pictures of the back (close up of the model and serial #'s) I take several pictures of the inside of the TV. some TV's have the Backlight board or boards on the side of the screen and some have the backlight inverter built in the main board, since u have already replace the main board u must have backlights separated. . Take close up shots of the board, and write down all the #'s from the board and when u order make sure u order the exact one..I never remove the bad board till I have the new one ready to install. I always go to ShopJimmy.com first to see if they have the part. Then I check Amazon, and then eBay. in that order.try to buy NEW boards if u can.. Hope this helps.
Mar 20, 2015 | Vizio E470VL 47 in. HD-Ready LCD TV
Samsung 46" LED - Screen goes to black every 15 sec and then comes back shortly. Do I need to replace tcon or main or is there something else possibly wrong?
Hi Todd,
Screen goes black means back lights go off. The power supply may not be responsible for this problem. Please check back light on command from main board. Good luck.
Jan 11, 2015 | Samsung " 46"" Class - LED - 1080p - 120Hz...
Insignia LCD TV screen goes black until hit.
Try to follow the inverter to backlight connections---either a loose or damaged plug (look for any plug with tape on it at the plug first) or on the board that powers the lights a bad solder connection or connections where plugs connect.
Oct 29, 2012 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Picture goes black, have sound, red light comes on at the on button, 60'' phillips tv
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 16, 2010 | Televison & Video
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Apr 29, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
