Question about Honeywell Heating & Cooling
Honeywell smartfit heating control showing error message F05 how do I fix this
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: My central heating system comprises
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
Posted on May 22, 2008
SOURCE: I have a honeywell smartfit
I had exactly the same problem. F4 code says the control valve has jammed --- but it hadn’t.
I ended up having to swap out the room controller and the base unit (I bought the pair since it was winter and I couldn’t ‘eff’ about)
On investigating (well, you have to don’t you?) I could find no obvious fault but did notice that a large electrolytic capacitor was across the actuator motor.
Since these things work by reversing the supply polarity to the motor to drive the actuator one way and the other it strikes me as strange that a polarity sensitive component, one that must be always connecter positive to positive, is used in the way that it is.
Bottom line, tough luck, mate. Replace the units.
Posted on Jul 31, 2008
  • 1214 Answers
SOURCE: Honeywell Smartfit Control Unit
You need to either call an electrician if your unable to, or do not have the knowledge to troubleshoot electrical circuits, or, get a multimeter and see that power is coming to the furnace/heater.
Reply back what type of heating unit you have (gas or electric), any other symptoms you've observed (including has the system ever operated before, and what changes may have been implemented to cause it not to operate) and the model, and we can be of more help to you.
Posted on Jan 22, 2009
Ive currently got a honeywell smartfit thermostat control which is displaying F24 which ive been told means i need to replace the control panel, again!! ive already replaced it once not so long ago (approx...
There are other universal replacements but if it was me I would stick with the honeywell parts. I know they are more expensive but in your instance where you already have a problem that is causing the control panels to fail I'm afraid you would make it worse by using other then factory replacements.Thank you
May 17, 2011 | Honeywell Heating & Cooling
My honeywell smartfit central heating control panel show the following; ''OFF'' and I can not turn it on no matter what butten I press. I tried to turn it on by the user guide . (main power is on in the...
Hello my name is Heath it will be my pleasure to assist you. The first thing you need to do is move the slider to the auto or once or cont position this should turn the system on.
May 01, 2010 | Honeywell Programmable Thermostat Heater
Honeywell smartfit controller not adjustable
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 10, 2010 | Honeywell Heating & Cooling
Jan 22, 2009 | Heating & Cooling
I have a honeywell smartfit but it keeps coming up with a F4 error
Jul 30, 2008 | Honeywell Heating & Cooling
My central heating system comprises a worcester bosch system boiler and honeywell smartfit controls. The problem I am having is that the central heating doesn't seem to knock off at the preset temperature...
May 21, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
139 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
