Question about Whirlpool Refrigerators
My frige is raining on the in side . And the draine is clear ,it is lean back so the door suts on its own . and the cooling fins don't have frost on them. But the drain keeps frezzing closed . So i rain a wire down the drain tub . And it is still doing it . the modle number is et8lfkxk005
  • mr fixit 236 Oct 03, 2008
    The drip pan goes to the hole . When i pore water in it there is nun on the pan. And the temp is right to . I can take all the food out . And it still does it . The wire was just to make sure the drain was clear. It douse not heat up. I kinda wonder if the defrost denator is going bad. the heater gets red . but not red hot like an ovens does .
    thanks i will give that a try . it sounds like it will work . thank you vermuch
    Problem Solver:
  • 21 Answers
OBVIUSLY THE DEFROST TIMER IS WORKING AND ALSO THE ELEMENT. MAY THE DRIP PAN IN THE FREZZER SECTION IS PERFORATED OR YOU KEEP THE FRIDGE AT MAX ALL THE TIME ALSO MAKE SURE IT HAS ENOUGH SPACE TO CIRCULATE THE AIR INSIDE OF IT AND OUT. ALSO MAYBE THE WIRE YOU RAN INTO THE DRAIN IT DOESNOT HEAT UP TOO MUCH.
Posted on Oct 02, 2008
  • JOSE SIN Oct 03, 2008
    WHAT I HAVE DONE ON SOME WHIRLPOOL REFRIGERATORS AND HAVE WORKED IS THAT I GET A DOUBLE PIECE OF BAILING WIRE AND PUT IN THE HOLE THE OTHER SIDE SWIRL IT TO THE HEATING ELEMENT THIS WILL MAKE THE WIRE HEAT UP AND KEEP THE DRAIN CLEAN GO JUST LIKE AN INCH INSIDE THE DRAIN HOLE.
    I HAVE DONE AND HAVE FOUND NO PROBLEMS AFTERWARDS I HAVE A COUPLE UNITS LIKE THAT AND THEY HAVE BEEN LIKE THAT FOR A COUPLE OF YEARS
    have a nice day.
Why water is leaking in freezer where cooling fins are
The defroster coil melts the frost build-up on the coils and the water hits the aluminum plate that guards the plastic drain from he heat of the defrost element, but the drain freezes over because the air temperature and the metal heat shield are still cold enough to freeze the drain. You can cut away a small portion of the metal pan liner and expose the drain to the heater coil while defrosting. I also wrapped a piece of copper 14 guage wire around the heating coil and routed it down the drain to heat it while in defrost. No problems after this fix.
May 31, 2014 | Whirlpool GB2FHDXWD Refrigerators
The freezer door wasn't closed properly overnight 2 nights ago and it still didn't cool properly after the whole day yesterday and today. There was a noise which I didn't recognize but now in retrospect...
Is RS261MDWP the correct model number? If you left the freezer door open there is an excess amount of frost covering the evaporators because moisture was drawn inside and has frozen on the evaporator and is too much for a normal defrost to get all of the ice off and drain into the pan below the refrigerator. It may have also frozen over the condensate drain and not allowing the water to drain. You may need to clean the drain hole and defrost the refrigerator manually and insure the evaporators are clear of backed up water. If you don't there is a chance the refrigerator will continue like this until you do. Let me know what the status is so I can help.....Sea Breeze
Does your model have two evaporators?
Aug 05, 2013 | Samsung / RS261MDWP
Water leaking ( not much , but regular) from bottom of both sides. Freezer section now frosted up. does unit need a service? have had a look online and this seems to be common problem and no real...
the most common reason for frost buildup/condensation is doors not sealing properly(doors out of alignment).
use a spirit level to ensure unit is level,leaning back slightly but not touching wall,adjusters are on feet on the bottom of the unit,then look along the doors to make sure all seals are tight.lastly even though they say frost free it is worthwhile doing a total defrost annually(leave the doors open)and wipe out with bicarb and dry thoroughly.before switching back on.
clean out vents/drains at the same time.
then if it goes wrong you know its gonner cost......
Apr 20, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
My freezer leaks when not freezing
Drain tube
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Mar 02, 2010 | Refrigerators
I have a ge tns22brcblbs and there is water leaking from the freezer into the frige. the frezzer and frige are working just fine im sure the water is coming from the defrost of the freezer but i need to...
Oct 30, 2009 | GE Profile Arctica Stainless Steel Top...
Ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Aug 20, 2008 | Danby (DAR604BLS) Refrigerator
The freezer of my magic Chief Side by Side is draining the water from the frost free cycle into the bottom of the freezer. It is running out the door and also poooling in the bottom of the freezer and...
There is a drain tube underneath the evaporator coils that has probably froze over. You'll probably have to take the evaporator cover off to access the drain area (the back wall of the inside of the freezer). You need to clear as much ice as possible from the area, then use hot water to melt the ice in the tube. There might also be a block in the tube (like a pea or corn) so you may still need to run something through the tube to clear that. Some things that might help prevent this in the future (other than not spilling a bag of frozen peas) would be to make sure the frige is level side to side and tipped back slightly, this will help the water run towards the drian. Tipping it back also helps the doors swing shut so you don't potentially leave a door. Also make sure the freezer is not too cold. Place a thermometer in the freezer and set the temp at between 5 and 10 deg above zero. Any colder will only freezer burn your food faster and cost you more electricity and put more wear and tear on the frige. You have to wait 24 hours between adjustments and check the temp after the doors have been shut for 6-8 hours (like first thing in the morning).
Jul 19, 2008 | Refrigerators
Freezer works fine. frige does not get cool.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 01, 2008 | Danby Refrigerators
Frige problem
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Aug 13, 2007 | Maytag MZD2768G Side by Side Refrigerator
Refrigerators Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
