Question about Hitachi Televison & Video
51F520 Intermitent brightness. Sound OK - Hitachi Televison & Video
    Problem Solver:
  • 39 Answers
Check picture tubes for shorts.
Posted on Oct 02, 2008
  • 800pctechs
    800pctechs Oct 02, 2008
    why dont you try it first, they tend to short intermittently once warmed up.
Intermitent loss of sound
Check the speakers first. If found OK, check and replace damaged component/s at its audio output section circuit. Check all the solder terminals at this section circuit first, before replacing any components.
Aug 22, 2013 | Televison & Video
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
My GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
Mar 14, 2012 | GPX Televison & Video
1993 Grand marquis radio sound system amplifier trunk mount intermitent reception - radio powered up -volume. tuning. working fine but intermitent soiund received from source to speakers.
you sound like you have a loose wire if your using the stock head unit you must of had to conn.alot of wire go back through follow from the head unit.If I were you get a audio control x-over.it will kick up the pre amp power.
Dec 18, 2010 | JBL Car Audio & Video
Screen darkens, very faint picture, sound still works. This is intermitent problem happens day or night in car plugged into car power. Thank You
go into the settings and turn the brightness up when the unit is plugged in and when it is running on battery mode (when it is plugged in it automatically goes into behicle mode and dims the display)
Oct 23, 2009 | Garmin nuvi 1300 Car GPS Receiver
No intm or washer. slow and fast ok
The intermitent system works off a circuit board which can not be tested by your means of your question. If the high & low speeds works fine the board is bad and should be replaced if sold separately from Chrysler
May 23, 2009 | 1998 Dodge Ram 2500 2WD
Sound OK but no picture
Another intermitent problem, It seem that theres a disable unsoldered part on the chassis that cause of it iether on the Cold side or Hot side.It needs to be trouble shoot.
Normally it gathered from the climate temperature changes
r_ic7
Nov 29, 2008 | Televison & Video
Intermitent no sound on digital, KDL26S4000 sony bravia TV
Try going in the settings and turning off "Steady sound". Or turn the audio setting to stereo, disable surround sound.
Steady Sound
You don't have to listen to commercials at a higher volume than the normal programming. This TV has a volume equalization feature for both program and commercials to enhance your audio entertainment.
Selvol
Bravia XBR 42"
Nov 22, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Convergence
Replace both convergence IC's part# STK392-040. Also check for burnt/discolored resistors nearby.
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
