I have Gateway MX8715. This morning I tried to turn the laptop on and no power. I tried just the battery and it would not come on. Battery out and AC only. No Power. I have checked to see if there were any known problems with this model. Could it be the AC, Battery, or maybe CMOS battery? I hope it is not the motherboard. It has been getting hot but I got a laptop cooling unit that sits under the laptop. Seemed to help that part. Any ideas? and Where is a realiable yet inexpensive site to order parts? Thanks Erin
  • eesims59 Oct 03, 2008
    I no longer have the warranty on the laptop. It ended in April.
    To Rody3. I have tried AC without battery and with battery without AC. I have no power at all. No lights. No indication of it powering on.
    Thank you
    Erin
  • Nebby31337
    Nebby31337 May 11, 2010
    Do you still have warranty on your notebook?
  • 29 Answers
I would suggest getting a universal power adapter like this one:
http://www.mikescomputershop.com/universal-notebook-adapter-p-28.html
be sure to set the power rating to the same volts as your old power adapter.
this will help rule out that as the cause. The next thing to check is the port where the power connection from the ac adapter is made on the notebook it could be faulty which is causing an unstable power connection. The worst case is the power module that is on the motherboard could be toast and you would then need to get a new mainboard for the notebook which will cost you some bucks. At that point just get a new notebook.
hope this helps let me know if not! and please vote!
Posted on Oct 03, 2008
  • 68 Answers
Try removing the battery and try with just the ac adapter if battery is totally flat can prevent laptop from starting up
Posted on Oct 02, 2008
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
My Gateway computer is plugged in but not charging. The ac adapter is brand new. Why?
Try this- Unplug the laptop, take out the battery, and hold the power button down for 30-45 seconds. After that, put your battery back in, plug in the AC adapter and turn it on. It's usually the solution in your type problem
Apr 18, 2011 | Gateway MX8711 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Gateway MT6840 Laptop will not power up
have you already tried to power up your laptop without the battery, only with the powersupply docked in?
If this works, you´ll have to replace the battery or use the laptop without a battery.
If this doesn´t work, just take the full battery from the other laptop try to power up the laptop without the power supply docked in.
If this works, your latop motherboard is broken and till it is replaced, you have only the chance to work with a battery and reload it with another latop.
Jun 02, 2009 | Gateway MT6840 Notebook
No power lights on gateway laptop model mx8711, power cord is working, does this model have a power fuse inside
Hi there.
The battery maybe faulty, remove the battery and try it on AC power only, there are no fuses that can be replaced inside the laptop.
If the laptop boots up on AC turn it back off and reinsert the battery and try to boot again, if it does not boot up then there is a problem with the battery and you will need a new one.
Good luck and thanks for using FixYa!!
May 12, 2009 | Computers & Internet
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
GATEWAY MX8715 WILL ONLY BOOT TO BIOS AND BOOT MENU SCREENS?
remove the new ram
then restart if that don't get you there
let me know
Jan 16, 2009 | Gateway Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
