Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Time setting is incorrect
I don't know how to resolve this problem and hope you do even though i think it's a manufacturer defect. The time on my phone is incorrect and has been for almost a year. The setting in my phone cannot take me to a menu where i can reset the time. It kind seems like a satelite connection that changes it all the time. What can i do or who can i call to speak to a person and not a recording.
  • opai Oct 10, 2008
    Thanks for your suggestion in helping me. I did what you have instructed me to do, but in my intial set up under setting i don't have the Time and Date option. Any other suggestions?
Go to settings - Initial Setup, and your top option is Time and Date. Select this option and the top item is the time (time zone date and date format below). Select that and it takes you to the screen where you can change the time.
Posted on Oct 10, 2008
My La Crosse Radio Controller clock will not set itself. I have tried setting the time manually but it always advances by approximately 1/2 hour after the manual set. Why?
I have the same problem with my 16" analog La Crosse wall clock - it was adding 30 minutes to the time every time I set it manually because, even in manual mode, it will continue to search for the signal. Mine is the WT-3161BL with blue dial. This series of clock, which are still being sold with a black and a white dial, have only mediocre reviews on Amazon. Users report they are unreliable or reliable for only a couple of years before they become incapable of keeping time. Others have received their radio-controlled clocks - as I did - with the hands disconnected (because they're flimsy). They are very nice looking (with a stainless bezel) but quality control, not failure to understand the directions, is the greater issue.
I am responding to this post even though it is old because these clocks are still being sold - and not cheaply, in most cases, either. It would be nice if someone could PUBLISH the La Crosse instructions for re-calibrating these clocks. Why? Because from my own attempts to repair this clock I think the issue is that the hands, especially if they become misaligned or fall off in shipping and are subsequently reattached, are not in sync with what the circuit board is configured to "understand" as the 12, 4, and 8 o'clock positions. What this means is that when you select your time zone it may not, in fact, advance to one of the above-indicated times and await the signal. It may advance in a seemingly random fashion. It's not random rather the hands are not aligned with what the circuitry expects to be the 12, 4 and 8 o'clock position. If this is the case no matter what time zone you select or how good your radio reception it will never "catch" the correct time.
I have seen references in some of the Amazon reviews for those who obtained warranty service that La Crosse Technologies "calibrates" it and then sends it back. If I had to guess, calibration of a radio-controlled (analog!) clock involves aligning the hands to the position the circuitry "expects" to be the default (factory) preset. If that is correct, pushing the Time Zone button will allow it to advance the correct number of revolutions. If the hands are not in the factory defaults due to shipping damage or a defect with the assembly, it will continue to set itself incorrectly.
What is frustrating about La Crosse Technology radio control analog clock design is that "Manual Set" continues, nonetheless, to engage the atomic time signal. So even if you compensate by setting the time manually it will, as it states in the user manual, continue to "search". When it thinks it receives a signal it will reset the time, if only partially. This accounts for why, when the radio signal is not strong enough, that these clocks cannot seem to "keep time". It also accounts for why, when they are assembled incorrectly or otherwise damaged (or repaired by re-attaching the hands) that it still cannot keep time.
If La Crosse would simply design their analog wall clocks so that Manual Set DOES NOT continue to search for the atomic time radio signal it would FIX a lot of the issues encountered by owners who A) received a damaged or defective radio-controlled wall clock, and B) those who do not have good atomic signal strength in their location but for which the clock continues to attempt to make use of an intermittent (incomplete) signal. Alas, this is not how La Crosse Technologies designs these analog clocks to function in Manual Set mode, so when the signal is too weak or the hands are misaligned it will continue to try to reset itself but inevitably to the WRONG TIME. (My suggestion to the manufacturer is that they design these clocks to at least have the option to go on working correctly in Manual time set mode, as opposed to having one linked to the other in such a way that when the Radio Control fails the Manual set options also go awry.) Alas, the only real solution that I know of, short of someone obtaining La Crosse Technologies factory calibration instructions, is to DIY replace the radio-controlled quartz module with an aftermarket (non-radio) mechanism. Otherwise, a good percentage of these clocks that did not survive shipping or were not assembled well to begin with will not hold the time.
Apr 11, 2015 | La Crosse Radio Controlled Atomic Clock
I am unable to unlock my new Zeepad. It keeps turning off.
I think you should return to manufacturer , cause if the zeepad came that way it's their problem
Sep 28, 2017 | ZEEPAD MID Android Tablet 7 Inch WiFi
Somehow current time has changed and I DON'T KNOW HOW TO RESET
go to the settings of your phone and change the date/time settings according to your time zone
Nov 01, 2012 | LG Cell Phones
While using yahoo messager i face with invalid cetificate problem and my messanger is hang up a number of time pls resolve my problem immediate thanks
Usually certificate errors is cause by an incorrect time and date settings. Check your time and date settings and make sure that the correct timezone and time and date settings are set.
Hope this help.
Apr 10, 2011 | Yahoo Messenger
When one or both ovens arte turned on, the pilot light keeps 'clicking' all the time it is on, even though the oven is lit. Can you help?
Sorry to read about your problem, I hope this helps you out.
you have a defective switch, on one of your knobs.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Rangemaster 110 (Gas) Kitchen Range
Hi I bought a Sharp pw-ac 890 Japanese to English dictionary about 18months ago but recently it has been acting strangely. Most of the time now when I switch it on the screen is dark and I can barely...
Hey guys,
i have also got same problem.. it seems to be manufacturing defect. i have requested one my friend who went to japan. I got fixed it for free, though it is not under warranty.. Japanese guys would fix it for free if it is known manufacturing defect.. Got it back couple of days back.. its working fine. at last problem solved after two years..
Nov 28, 2010 | Sharp PWE550 Dictionary
My computer alerts that the battery is low, then goes to hibernate. Even though it is plugged in to AC, AND/OR the battery is at 99% power seconds before? What's wrong?
1. the battery wasn't charged properly the first time that is it didn't get a full 24 hour charge.
2. The battery is defective and is giving an incorrect reading.
3. Usually the batteries are Lithium Ion batteries and have what is called "smart
technology and have electronic logic built into the case which is read by the computer to
give indication of status of the batteries.
4. I suggest that you contact the manufacturer for a replacement. Some Lithium batteries
from that manufacturer are in "recall status".
5. check the manufacturer site for the recall list and if your model PC is on the list request
a replacement battery.
Oct 06, 2010 | Acer Aspire One PC Notebook
My son seems to have set his Casio Wave Ceptor wv 58u to the incorrect time ..god knows how !!..any Idea How we correct it !
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem. thanks
Aug 17, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Cant Download Certain Updates
I don`t know if you are speaking about a game console or a pc, but if it`s a pc then I think your problem is due to the date and time set wrongly. Go to control panel-date and time and reset it to the right time. I think even if you are talkign about a game console that accesses the net , the problem might be the same, that is the time is set incorrectly.
May 14, 2009 | THQ WWE Smackdown Vs Raw 2009
2 LABELS COME OUT
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Oct 13, 2007 | Zebra LP 2844 Thermal Printer
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
