Question about RCA DRC8335
Resister burnt I need the value of resister RU83,It is on the VCR board. Thank you.
  • 1 more comment
  • Anonymous Oct 15, 2008
    I have the same problem. I found a Heat Damaged resistor and diode on the upper right side of the VCR PC board (by the power supply board). The location of the components are “RU83” and “DU83”. It appears that "DU83" shorted causing "RU83" to burn up. I was wondering if you happen to know the value for "DU83" (mine isn't readable). I would recommend that you check "DU83" if you have not done so already.
  • lesfix Oct 20, 2008
    DU83 is also shorted in my unit. I do not know the value, no markings on the part. On the board it is marked as a zenor diode and goes to a 47uf - 16 v capacitor. Thanks for telling me about the diode.
  • PicaDude Dec 14, 2008
    Same problem ... VCR section of my DRC8335 not working. Have buned-up Zenner Diode DU83 ... wish to replace it with proper value when discovered ... Reisitor RU83 looks OK. Thanks!
My unit is showing 14.7v on DU83. That's getting too close to the 16v limit on that cap. RU83 in this one is 1K ohm.
Posted on Sep 07, 2010
  • 19 Answers
Guest and Lesfix. RU83 located on the DRC8335 VCR PCB is a 51ohm 1/4 watt 5% tolerence resistor, color coded green-brown-black-gold. As to zener diode DU83, I haven't been able to determine it's value yet but am working on the problem.
Be aware when either or both these components fry, this indicates you need to replace the following two overheating capacitors on the power-supply board, which were directly resonsibile for knocking them out:
• C216 1000µf 16 volt (upgrade to 35 volts)
• C218 1000µf 10 volt (upgrade to 35 volts)
Could you email me regarding this problem when you have time. Mention Fixya and DU83 in the subject line so I realize it's from you. Thanks. mikeadams110@yahoo.com
Posted on Dec 08, 2008
How do you by-pass ignition switch on 1980 Chevy Silverado
You can't, without a bypass kit and the orginal key or resister value to use in the bypass kit. The theft system on the truck is a VATS system that uses a resister in the key that must match the resister value in the computer to start the car. No resister match, no start. The kit eliminates the resister key by hard wiring the resister permanently in the vehicle. You still will need the key to mechanically unlock the steering column and turn the ignition cylinder.
Sep 23, 2017 | Chevrolet Silverado Cars & Trucks
How do you bypass the security system on 94 Cadillac sedan deville
you need to tear down the steering wheel and get to the wires that read the value of the key resister ~~ then you need to solder in a resister of the correct value and from then on the key resister will no longer be needed.
chris...
Sep 26, 2012 | Cars & Trucks
Maytag MDB7100AWB dishwasher board burnt resister
first of all they wont give you any specs on circuit boards for most appliances,they just want you to replace the board besides that,if a resistor burnt its because there was a heavy current draw on another component that is supplied by this resistor and you would need to locate this defective part such as a motor/solenoid/heater or the new resistor will end up in the same manner,the 2 oozing parts are probably capacitors leaking their die-electric compound from heat and age so they are in need of replacement too,you might go online and ask somebody with a board like yours for the part values,but still you need to find the main problem for the problem on the board first
Aug 12, 2012 | Maytag MDB7100AWB Dishwasher
Circuit board defective
If you have warranty then go to the shop from you have bought it.
Jun 20, 2012 | Computers & Internet
Blown resister #46 need resistance value or color bands
From what if read number r46 is 150ohm im looking for the value of r45 hope it helps
Apr 22, 2009 | Yamaha YST-SW015 Subwoofer
Power supply burnt
R106 is a .5 ohm. It is green,black,gold, and silver. I believe it is a 1/2 watt resister
R103A is a 27 ohm and R108A is a 470 ohm resister.I have no schematic.
Sep 22, 2008 | RCA DRC8335
Burnt Resistor
You can tell the person at Radio Shack by telling them the number and the color and order of the stripes on the Resister and he/she can get it for you.
Feb 22, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Burnt Resister
where are these resisters located and whats the part location number on the board
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Duraband CD-2036 Cassette Player/Recorder Problem
so your telling me that your the one to repair this player?
i suggest that bring that thing to registered technicians. They are the one responsible for that.
Dec 04, 2007 | Durabrand CD Player with Cassette...
RCA DRC8335 Logo
1,316 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
