Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Error flashing and won't reset.
I have an Er message on my Frigidaire that is just over a year old. On the display panel the indications Sensing, sanitized, Clean, Drying, and the low rinse aid symbol are all flashing along with Rinse Only, sanitize, and no heat dry buttons on the upper selection panel. Nothing happens when you press the Clear button. I tried cycling the power The PF flashes and won't reset untill after pressing the clear button serveral times. It then goes back to the previously discribed Er. Does anyone have any suggestions
  • donnylee Oct 18, 2008
    I have the same problem. The only way to get the ER (as well the other lights: sensing, sanitized, clean,drying, and low). The Hi temp wash light is also flashing on the top cycle pad. When I turn the breaker Off and on the PF flashes. When I push the Clear botton "de" appears and then it goes blank.
  • Anonymous Mar 15, 2014
    Error code er with china crystal and heated dry/lock button flashing???
    Sergeant:
  • 409 Answers
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Posted on Oct 02, 2008
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Apr 13, 2010 | Frigidaire PLD4375RFC Dishwasher
There is an ER message flashing.we tried pressing cancel but nothing happens. it's like all the settings are frozen
This is a Common Error Message. Try to Disconnect the Power Supply, and wait for few minutes, say 30 minutes to Turn it ON.
If still ER message is displayed, you need to Replace either Touchpad or Control Board.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Frigidaire Dishwashers
ER FF in display ,DISPLAY IS LOCKED, LOUD NOISE
er ff indicates that the computer on your refrig is not sensing freezer fan operation. a guess as to your problem is that the fan is hitting on ice (the noise your hearing) and teh fan is not able to reach operation speed causing the error code. the fix would be to remove the ice from the fan area either maually or by unplugging the unit and letting it defrost for several hours. also to reset the computer you will neeed to unplug it for a few minutes then plugging it back up. hope that helps thanks Peyton
Feb 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error Message 'Er' on frigidaire dishwasher
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
Jan 29, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Jan 01, 2009 | Frigidaire PLD4375RFC Dishwasher
I have this code error on my dishwasher frigidaire gallery Sensing Sanitazed......Er......Low Clean.......................*
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
Jul 24, 2008 | Frigidaire Dishwashers
Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Nov 15, 2007 | Frigidaire 24 in. GLD3450RD Built-in...
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
1,103 people viewed this question
Top Frigidaire Dishwashers Experts
Electrolux
Electrolux
Mike Cairns
Mike Cairns
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
