Question about Refrigerators
Don't know how to remove drip tray
I have a 9 yr old top freezer sears refrigerator. I see the drip located at the back but I don't see how to remove it or drain it. It looks as if it is attached to the compressor. I am a victim of hurricane Ike and lost my power for 8 days the stench iskilling me please help
    Sergeant:
  • 409 Answers
the drip pan is usually accessible through the front behind the kickpanel. the kickpanel is attached with 2 screws. if you remove the kickpanel, you'll be able to pull out the drain pan.
Posted on Oct 02, 2008
Dripping water
Mine had the same problem today. I found the drip tray under the screwed on panels in the freezer was full.
There is an evaporative tray above the compressor in back, and feeding that was a drain pipe that was blocked with crud. Removing and cleaning the cap made it flow freely again. Hopefully that fixes it.
Jan 23, 2014 | Sanyo SR-1030W Top Freezer Refrigerator
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
Oct 29, 2013 | Refrigerators
Water dripping from freezer into refrigerator
Just fixed my refrigerator last week that was doing the same thing. Water was dripping from the back top of the refrigerator and it was the drainage line in the freezer had frozen up and was plugged. Emptied the freezer and removed the bottom panel from the freezer and found large layer of ice. Turned freezer off and let everything melt. Then the hole in the back bottom of the freezer on the metal tray became visable. Contined to thaw until warm water would drain into the tray under the freezer. Was not hard at all and much better not cleaning up the water dripping all the time.
Jun 07, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Have an 8yr old Kenmore top freezer. Water is dripping from top of refrigerator section,from back right side of a vent. Have made sure food is not blocking circulation in freezer. Help!
Your freezer has a drain tube located behind the: freezer ice tray back rear plastic cover; It leads to the defrost tray at the bottom of the refrigerator. remove the back rear plastic cover, the drain will be located at the right side of the coils.
flush the tube out using a funnel and, a pan of hot water. empty the floor defrost tray as you do this.
Mar 30, 2010 | Refrigerators
Our 3 yr old LG Model LFC25760SW French door refrigerator over freezer is forming ice on the bottom of the freezer compartment, beneath the drawer. The ice maker switch is off. The water is coming from the...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 25, 2009 | Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Cant find Freezer drain hole
The hole is located in the middle of the coils or on the end. See the slope of the collection tray right under the coils. Might be hard to find because the ice would be blocking it. So take some table salt say two spoon fulls and place in the middle of the collection tray to melt the ice. Will melt fast. Then flush out with small amount of water. Be sure your frig is unplugged and remove the back panel. Let me know if you need anymore help.
May 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Water leaking
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Roper RT21SKXLQ Top Freezer Refrigerator
Refrigerators Logo
305 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
