Question about iLO V27DMBX Television
Where can I get a ownwes manual for a 27" ilo tv
What can I do if I am watching my tv and a few seconds later it blinks out that about five to ten mins later it comes back on?
  • utahjeff Jan 24, 2009
    Where can I get an owner's manual for the ilo 27" dtv, model 2700 series or the 2794?
  • iLO Master
  • 5,568 Answers
Failing power supply-
Nearly all modern electronics uses a 'switched mode power supply.'
They are more efficient, also much more prone to failure but offer the added benefit of being designed so a 'downstream' fault will cause the supply to enter a cyclic state to avoid setting fire to your home.
The supply itself will also cycle if it has an internal problem; once again, to prevent destroying itself or anything dependent on its outputs.
Supplies built a couple decades ago could only do this by blowing a fuse and there are conditions that can occur that would not blow the fuse but would allow overheating and further damage as well as fire.
The most common failure is of electrolytic capacitors which sometimes will show their illness by causing a bulging top or depositing a crystaline trace around their base.
Often though, they show no outer signs of failure but their value can shrink to tenths of a percent of the specified due to poor seals and defective chemicals. These can only be found through measurement with a capacitance meter with a DF (dissipaton factor - loss) capability.
They will be in size from ~ 3/8" to 2" in height, ~1/4" to 1 1/4" in diameter, cylindrical, perpendicularly mounted on the board.
They will have markings on their shrink-wrapped sleeves (color can be any) and range from ~ .1 to several hundred uFd. with voltages from 3-4 volts to hundreds.
Power supplies are often mounted on a separate board (since they are often outsourced) so if you are adventurous, take the back panel off and take a look.
Posted on Oct 06, 2008
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Ilo mp3
I have had the ilo for about five months. I have changed the battery several times. The only thing that happen is the back light comes on just blinks! What can I do to correct the problem.
Apr 10, 2008 | iLO (2 GB) MP3 Player
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Sony tv kv-29F1U
tuner needs replaced or taken apart and cross your fingers soldering joints, use silver solder look hard with magifiers for solder cracks or bad joints and grounds inside tuner.
Jan 18, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My tv shuts off in seconds!
If it's that new call the place that it was purchased and see about manufacturer warranty... It should have a one-year parts and even that will help...
The problem you're describing is likely the center led or prisim. The unit thinks there is a tape in the tape path and attempting to load it. Not an expensive repair but highly complicated for the average person...
Nov 19, 2007 | Philips Magnavox 27MS343S 27" TV
No picture blinking stand by light
I hve worked on a number of these units , your description is typical of a shorted blue picture tube. The protection circuits in the tv detect that there is a problem thus shutting the unit down to prevent further damage. Sony had a bad run of picture tubes in this series. The replacement cost of the tube is about $250 plus labor. My estimate would be for the repair about $400-500 depending on where you live and how honest your local technican is. I will caution you however, that you could replace this tube and the red or green could go. These would not be covered by the technicians warranty. When these sets are working, they have a superb picture and it is easy to get lured into fixing them. Scrivitron
Jun 13, 2007 | Sony KP-51HW40 51" Rear Projection...
iLO V27DMBX Television Logo
301 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
