Question about Hotpoint Washing Machines
My washer my hotpoint washer top load g162 it was working the other day now when i put clothes in it. it never stop filling up with water it over flow and it wont do nothing but spin it wont wash and the water wont stop any idea whats wrong.
I'm having the same problem. clevonstewar , did you find out what it was and how to fix it?
Posted on Apr 25, 2010
    Sergeant:
    Champion:
  • 223 Answers
It sounds like you have a faulty inlet valve or module. Hope this helps.
Posted on Oct 02, 2008
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
Feb 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Water will not stop filling tub.
the problem is that your pressure switch is not working properly. if you take the screws out of the back of the head you will find the pressure switch. first unplug the washer then undo the hose from pressure switch. blow trew the hose, then blow into the pressure switch if you hear the pressure switch click then re assemble and try again put on small load and watch if fills almost to the top or over flows replace pressure switch
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint topload washing machine won't water won't stop running.
washer top load will not stop filling even when turned off
Dec 01, 2008 | Hotpoint VBSR3100D Top Load Washer
Whirlpool ultimate care 2 water wont stop filling...over flowing everywhere.
Your level switch hose has come loose.first open the display panel to check in back of water level switch,and look for a hose that is not attached to the back of it.
Jun 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer PAV2300 water over flow
from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
Feb 21, 2008 | Washing Machines
Washing Machines Logo
146 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
