Question about Xerox Office Equipment & Supplies
I want to add an store email addresses on my xerox phaser 6115mfp
    President:
  • 2,072 Answers
You need to use control center , which can be found at Xerox.com .
But here are the steps.
The MFP ControlCentre (MCC) provides an easy-to-use Graphical User Interface (GUI) that simplifies configuring the Phaser 6115MFP and managing fax directory lists from a computer over USB. The MCC stores configuration and setting information in a .dat file that is uploaded from the computer to the Phaser 6115MFP.
NOTE: It is also possible to save the .dat file to a directory on the computer.
To program dialing and enter recipient e-mail addresses using MCC:
  1. Click on the [Start] button, then point to [Programs], select [Xerox Office Printing], then [Phaser 6115MFP], and then click on [Xerox Phaser 6115MFP MCC]. The MCC window will be displayed.
  2. Click on the [Connect to Machine] button. 'Connection Status: Online' will be displayed in the MCC window.
  3. Click on the [Download] button. The current .dat file will be downloaded to the MCC.
  4. Click on the [Menu] button.
  5. Click on the [+] on the left side of the window to configure Speed Dial, One-Touch Dialing, Group Dial, and e-mail addresses.
  6. Enter the required settings, and then click on the [OK] button.
  7. When finished, click on the [Upload] button, and then click on [Yes] to save these settings to the Phaser 6115MFP.
  8. Click on the [Save] button to save the new .dat file to the computer.
  9. When finished, click on the [Disconnect] button.
Posted on Oct 03, 2008
Image unit depleted
Image unit is used up, please replace 108R00691 Phaser 6120 Imaging Unit up to 20,000 pages black/up to 10,000 pages color
Dec 03, 2013 | Xerox Phaser 6115MFP/N Laser Printer
Ink not fusing to paper
Make sure you indicate the right paper type and weight on the print driver. The same that you are feeding your printer with.
Aug 27, 2010 | Xerox Phaser 6115MFP/N Laser Printer
It's producing two vetical white strips across the page when printing.
Toner drops from the cartridge onto a dark glass (laser?) below and prevents that part of the image from being transferred. Wipe clean and the problem disappears.
Jul 28, 2010 | Xerox Phaser 6115MFP/N Laser Printer
What does image unit depleted mean on the display screen and how do i fix it thanks
it meants that the image unit needs to be replaced. You can order it from xerox or any computer store.
if you have trouble finding a imaging unit, we can help get one for you.
thanks adi
Dec 17, 2009 | Xerox Phaser 6115MFP/N Laser Printer
Printing problems
Hi!
Could be a couple of things, but it sounds like the tires on the paper roller have worn out.
Like tires on a car, the slightly abbrasive surface of the rubber tires on the paper roller will go smooth over time...causing the rollers to slip on the paper instead of pulling it throuh the printer.
It's a relatively cheap/easy to install part.
You can contact Xerox for the part: www.xerox.com or other websites such as: www.sparepartswarehouse.com.
There may also be a local Xerox service centre where you live (most major cities have at least one) & the tires will be a very common part for them.
...If it's not the tires, it could also be the mechanism that lower the roller onto the paper. If this is damaged (or not calibrated correctly) the printer will have problems feeding the paper through as well.
The only easy suggestion here (if you're not comfortable replacing parts yourself) would be to take it to a registered Xerox service centre for maintenance.
Hope this helps!!
Dec 04, 2009 | Xerox Phaser 6115MFP/N Laser Printer
Mac upgrade means Xerox printer won't print!
There are apparently incompatibilities between some Xerox drivers and the security-improved Snow Leopard. It seems that many pieces of software (and drivers) relied on not-so-clean techniques to cut corners while operating. These techniques are no longer allowed by Snow Leopard (the same problem afflicts XP SP3, Vista and Seven).
This article lists several problems, explanation and (perhaps) fixes:
http://www.ucalgary.ca/it/news/4366
Meanwhile, Apple is working to some workarounds too (there is an update linked in the article which may be of interest to you).
Nov 08, 2009 | Xerox Phaser 6115MFP/D Laser Printer
Replace Paper Tray Message won't clear
On the right side of the tray, there are 3 rectangular holes. The "plug" goes in the top hole but, if it came out, it probably won't stay in. I've taped a piece of sheet metal in the hold before to get by. You can buy the part for a few bucks from xerox or inktechnologies. There is a lot of pressure on this plug so it takes something pretty strong to hold.
Mar 12, 2009 | Xerox Phaser 6115MFP/N Laser Printer
Xerox Phaser Networking
Have you tried just reinstalling from original Xerox CD. This worked for us in a similiar situation.
Oct 12, 2007 | Xerox Phaser 8400 Laser Printer
231 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
