Question about Dryers
We are trying to install a dryer belt onto a GE older moder dryer and can't figure it out. The model no is GDX8060RT429
  • 943 Answers
Hi. thanks for the question. remove the top. lift , remove front. slide belt on drum .clean all lint. reinstall front and top. pull away from wall. remove back panel. motor on right idler pulley on left bring the belt down to push idler down ,to give the belt tension .put belt around motor pulley . thanks the appliance doc
Posted on Oct 02, 2008
I have a GE profile dryer model# DPVH890Ejww upon starting it turns for about 2 seconds then stops turning.I was going to check the belt ,But couldn't even figure how to get the back off and I'm very...
couldn't pull up the model number so if it's a newer model you have to take out the top panel screws in the back,then go to the front and pop off the timer knob and there's a screw there that lets you remove the front control panel and then you can get at the other screws that hold the top on,this isn't an easy dryer to work on,it has a funky belt system in it.if it's an older model open the door and look up at the top panel,you'll see two screws there,remove them and remove the top panel,then look down the sides and you'll see a screw on each side remove them and remove the front panel.hope this helps.i'm going by memory and unplug the dryer before you get into it.
Oct 21, 2013 | GE Dryers
Need belt diagram for GE dryer, Model No. DBSR453GB3WW
try this site it has free manuals for dryer repair, you should be able to find all you need there....
Nov 11, 2011 | Dryers
Belt replaced around drum, too loose! Parts store insists it is the correct size for GE dryer. Model # DBXR453GT3WW (1996) Can't figure out what is wrong?
The part# i have for that model number for the belt is WE12M29 the previous part number for that was WE12M22 is either of those the part number for the belt ?? if yes it should be the correct one
one more thing that may help ya is view the diagram here of how it fits onto the idler pulley/motor pulley http://www.repairclinic.com/Dryer-Belt-Diagrams for your dryer it will be DIAGRAM L
GENE
Aug 29, 2011 | GE Dryers
I need to know to route my dryer belt on my GE dbrl33ee2ww dryer as the belt slipped off and I did not see the correct path
Hi Roy, W/D here. I wrote this earlier for another person, but it works just as well twice.
You already have the diagram! (Bear with me).
Make sure that your power is off.
If you look carefully at the drum, you can see where the old belt was running.
Place your new belt in that position.
Now, place the belt over the motor pulley (It is in the same plane as the belt position on the dryer).
Pull the tensioning pulley past the belt, and ease it into place.
Roll the drum several revolutions by hand, just to get the belt tracking completely right.
Put it all back together and you're done!
Best regards, --W/D--
Feb 01, 2011 | Dryers
Belt installation
HI, Looking at the idler assembly from the back, move the idler wheel to the left (spring loaded).
Slip the belt on the motor pulley with ribs touching pulley. Now let the idler pulley rest againdt the back side of the belt.
I hope this helps you.
Please let me know if I can help further.
Vic
May 23, 2009 | GE DBL333EA Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer belt
hi thanks for the question . look at the belt and motor you see the belt hanging down . with your right hand go to the right of the pulley . with left hand double the belt and push underneath the bracket , and install on motor pulley. hope this helps you thanks the appliance doc
Sep 30, 2008 | Whirlpool Dryers
Ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
