Question about Kitchen Ranges
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later on I went to use the oven, pushed the bake button and the lock light would flash. I could not get past that to get the oven to come on. I turned off the electricity and then turned it back on and the lock light still blinked.
  • 5 more comments
  • friendscreek Oct 03, 2008
    Hi Huuum!
    I kept the electricity off about 10 minutes. It did not lock up again. But the lock indicator light continued to blink when I tried to turn on the oven. The Model # is DF255677. We bought it new in either 98 or 99.
    I appreciate you taking the time to assist me with this problem.
    Friendscreek
    The oven does not work, the indicator light is still flashing. Do you know if there is a reset button somewhere?
    Thanks again for your time,
    Gratefully,
    Friendscreek
  • friendscreek Oct 04, 2008
    Whelp, I held down the clock button, held it until F1 appeared then I pressed cancel and it cleared. Unfortunately the lock indicator is still blinking and will not allow me to turn the oven on. It's late....I'll try turning off the electricity again tomorrow.
    Thanks again for everything. I'll let you know if anything happens after I turnoff the electricity.
  • friendscreek Oct 06, 2008
    Hi Huuum,
    Well, Yesterday I turned the electricity to the range off for 20 minutes. No difference. I guess I'll just have to call a repairman. I appreciate you trying to fix it for me. Very kind of you.
    friendscreek
    Hi Huuum,
    friendscreek
  • mert3 Dec 24, 2008
    I cleaned my oven and now my unlock light will not go off. help please
  • auntnan131 Jan 19, 2009
    I used the self cleaning feature......... the lock light would not go off, messed with it for a bit unplugged it for about 3 mins. It went out then later when trying to cook it came back on and wouldn't go off, it shut down the oven........... Now can't get it to go off...........
  • 750 Answers
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Posted on Oct 02, 2008
  • 2 more comments
  • Neil Golan
    Neil Golan Oct 03, 2008
    You said, you kept the electricity off about 10 minutes.
    So, that part is soled? It's unlocked now ?
    You said, But the lock indicator light continued to blink when you tried to turn on
    the oven.
    Question: Did the oven operate despite the lock indicator light flashing?
    If the answer is yes, then the indicator light is giving a false signal and is faulty!
    Let me know the answers!!!!!!!!!
    If it works you can use it like that and ignore the flashing light OR get the switch or sensor fixed!
    The Model # is DF255677. You bought new in either 1998 or 1999.(ten years)
    Here is a report that I just read !
    Perhaps you will find it interesting!
    Repair or replace?
    When to pull the plug on your old range
    Typically, you'll also find a troubleshooting section for more-serious problems
    in the owner's manual.
    Should you pay for a repair or buy a new model?
    The answer depends mostly on the age of your range,
    How much you bought it for,and the cost of the repair.
    Follow these guidelines:
    When a repair makes sense.
    If your range is under warranty or less than four years old ,
    paying for a repair makes sense.
    Note that ranges under warranty might require service from a factory-authorized technician;
    readers have found them on a par with independent repairers.
    When a repair might be a wise choice.
    If your ranger is out of warranty and is four to seven years old,
    it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
    But you might want to buy a new model even at this stage,
    given that today's models have added features.
    Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
    are 43 percent more efficient than conventional models built before 2001 and 56 percent
    more efficient than those built before 1993.
    When it pays to replace.
    The repair costs more than half the price of a comparable new range.
    Data also shows that it doesn't pay to fix a less-expensive range
    eight or more years old.
    Thanks to better recycling programs, less than 10 percent
    of ranges you replace are likely to end up in a landfill.
    Please do not forget to give a solved rating before you sign off!
    Thank You, HUUUM
  • Neil Golan
    The only reset that Admiral has is to power off and then later power on, as I advised you earlier.
    Try this as if there is and error code!
    When there is an error code for this brand range you would "hold down" any button,
    except the cancel or the up or down arrows .
    If this does not reset or clear errors codes like F-1 or F- anything then the control panel must be changed. The part is $137. and $65.labor at maytag.
    BUT, I think this is not the control panel, but the lock switch or sensor!
    if the above does not work for you, unfourtunatly will need to call service This is a Maytag range.
    I hope it clears for you with thie hold down of the button!
    Let me know how it goes!
    I wish I could be there to be hands on!
    Please remember to leave a rating for me before you leave!
    Thank You Huuum
    If you think of any other questions off shoot them at me!
  • Neil Golan
    Neil Golan Oct 04, 2008
    Since this does not reset or clear it,
    at Maytag.
    sensor which should much less for the part.What other choice do we have
    at this point!!
    if the above does not work for you, unfortunately will need to call service This is a Maytag range.
    I hope it clears for you with the hold down of the button!
    Please remember to leave a rating!!!!!
  • Neil Golan
    Neil Golan Oct 06, 2008
    Let me know what happens!
    Huuum
Self cleaned it locked how do i unlock it
door locks on self cleaning ovens , lock automatically so that one cant open door and burn oneself , they should unlock after oven has cooled completely after cycle is over and is safe to touch again , this can take several hours to complete this cycle
Jan 20, 2016 | Samsung Stainless Steel Gas 30" 30 Inch...
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Gas range oven door with not open
    Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
    Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
    How do i start self cleaning oven
    To Self-Clean:
    1. Press SELF CLEAN to set the clean time to HI (4 hours
    30 minutes).
    2. Press the TEMP/TIME "+" or "-" keypads to cycle between LO
    and HI clean time.
    3. Press START.
    The oven door will automatically lock. The CLEAN indicator
    light will be displayed. The time remaining will also be
    displayed.
    4. When the self-clean cycle is complete and the oven cools, the
    CLEAN indicator light will turn off.
    5. When the oven is completely cooled, remove ash with a damp cloth
    Remove the broiler pan, grid, cookware and bakeware, all
    cooking utensils, oven racks and aluminum foil and, on some
    models, the temperature probe from the oven
    Dec 07, 2012 | Maytag MGR5751AD Gas Kitchen Range
    Lost Manual and would like instruction on how to set for self clean cycle?
    Make sure you have everything out of the oven, including the oven racks.
    1. Press SELF CLEAN.
    2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
    3. Press START.
    The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
    displayed.
    4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
    indicator lights will turn off.
    5. When the oven is completely cooled, remove ash with a damp cloth.
    Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
    If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
    It is also recommended that you remove anything plastic from the top of the stove during cleaning.
    Nov 27, 2010 | Whirlpool RF263LXTQ Range
    I was using the self cleaning function on my kitchenaid dual fuel range when about half way through the cycle the digital display went blank (i.e. no lights were on at all) and now 2 hours after the cycle...
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Aug 19, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
    Lost instructions - I have my oven cleaning how
    Typical oven self clean cycle is 3 hours. Oven needs to cool down to under 550 degrees before door will unlock. Download a use and care manual at http://www.geappliances.com/service_and_support/literature/
    Nov 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    How do use self clean service?
    CAUTION: SHOULD AN OVEN FIRE OCCUR,
    CLOSE THE OVEN DOOR AND TURN OFF THE
    OVEN. IF THE FIRE CONTINUES, USE A FIRE
    EXTINGUISHER. DO NOT PUT WATER OR FLOUR
    ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
    To set the controls for a self-clean cycle:
    For satisfactory results use a 2 hour self-clean cycle for
    light soils and a 3 hour cycle for average to heavy
    soils.
    1. Be sure the clock shows the correct time of day.
    2. Press Clean. "— — —" appears in the display.
    3. Press the Up Arrow until "3:00" appears in the
    display for a 3 hour cycle, or press the Down Arrow
    until "2:00" appears in the display for a 2 hour cycle.
    4. As soon as the Up Arrow or Down Arrow is
    released, "CLN" appears in the display.
    5. As soon as the controls are set, the motor driven
    lock will begin to close automatically and the "LOCK"
    indicator light will flash. DO NOT open the door while
    the light is flashing (it takes about 15 seconds for the
    oven door to lock).
    6. The "LOCK" light will glow until the cleaning cycle is
    completed or cancelled, and the oven
    temperature has cooled.
    When the self-clean cycle is completed:
    1. The time of day or “END” will appear in the display
    window and the “Clean” and "LOCK" light will continue
    to glow.
    2. Once the oven has cooled down for about 1 HOUR
    and the "LOCK" light has gone out, the oven door can
    be opened.
    3. If “END” is in the display and the “Clean” indicator
    remains on, press Clear/Off. The time of day will
    appear in the display.
    NOTE: When the oven is cool, wipe away any residue
    or powdered ash with a damp cloth or paper towel.
    Stopping or interrupting a self-cleaning cycle:
    If it becomes necessary to stop or interrupt a selfcleaning
    cycle.
    1. Press Clear/Off.
    be opened.
    3. Restart the self-clean cycle once all conditions have
    been corrected.
    How the ES 200 operates:
    CAUTION: NEVER ATTEMPT TO REMOVE EITHER
    THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
    ELECTRICAL POWER FROM THE
    RANGE. ELECTRICAL POWER IS CONNECTED
    TO THE ELEMENTS WHENEVER ELECTRICAL
    POWER IS CONNECTED TO THE RANGE.
    The ES 200 electronic oven control system is made up
    of three parts that control the bake and broil elements,
    and the locking of the door in the self-clean cycle.
    1. Electronic oven control.
    2. Oven temperature sensor.
    3. Oven door lock mechanism.
    Dec 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
    Whirlpool Flat top Accubake self clean 24 inch
    Of course - Empty the oven and clear off around it.
    The AUTO-CLEAN cycle time is adjustable, from 2 hours
    30 minutes and 4 hours 30 minutes in 15-minute increments.
    Suggested clean times are 2 hours 30 minutes for light soil and
    4 hours 30 minutes for heavy soil. The last 30 minutes of the
    cycle is for cool down.
    To Self-Clean Using AUTO-CLEAN
    1. Press AUTO-CLEAN.
    2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
    desired self-clean cycle time.
    3. Press START.
    The oven door will automatically lock. The “DOOR LOCKED”
    and “CLEAN” indicator lights will be displayed. The time
    remaining will also be displayed.
    the “DOOR LOCKED” and “CLEAN” indicator lights will turn
    off.
    5. Once the oven is completely cooled, remove ash with a damp
    cloth.
    To Delay Start Self-Clean Using AUTO-CLEAN
    2. Press the TEMP/HOUR “up” and “down” arrow pads to set
    the desired self-clean cycle time.
    3. Press START TIME.
    4. Press the TEMP/HOUR “up” and “down” arrow pads to set
    the desired start time.
    5. Press START.
    The oven door will automatically lock. “DOOR LOCKED” and
    6. When the self-clean cycle is complete and the oven cools,
    off.
    7. Once the oven is completely cooled, remove ash with a damp
    cloth.
    Owner, Warranty, Installation and Parts manuals are here:
    http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
    Sometimes search links don't work when copied.
    Here is the direct link to the Use and Care Guide:
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
    Page 16 has the above instructions.
    God Bless!
    -Ptochos
    Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
    How to clean gas oven
    hi,
    use a 2 hour self clean cycle for light soils and a 3 hour cycle for heavier soils. The kitchen area should be well ventilated using an open window, ventilation fan or exhaust hood during the 1st self clean cycle. This will help eliminate the normal odors associated with the 1st self clean cycle.
    when the controls are set, the oven door will lock and the “LOCK” indicator light will flash. DO NOT open the oven door while the light is flashing
    Mar 29, 2008 | Kitchen Ranges
    Kitchen Ranges Logo
    481 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
