Question about Husqvarna Garden
Husqvarna leaf blower, replace starter cord Model 132 HBV
Starter cord broke, how do we replace it.
  • 163 Answers
Remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on Nov 30, 2008
130BT Blower can't pull start cord.
Can be a couple issues. The obvious is seized. The other is a broken jammed connecting rod. I would put some oil down the plug hole and let it sit overnight. Then after a day or so...try again with the wratchet. In both directions, forward then backward just to try and free it.
Nov 22, 2015 | Husqvarna 130bt 130 Bt Gas Powered...
I can't pull the starter cord. It is stuck
You have one of three problems.
1) The engine is flooded/hydrolocked. Pull the spark plug and see if the pull starter frees up.
2) Unit was left out and got wet. Take starter assembly off unit and see if is rusty and shoot penetrating oil into spring housing avoiding the rope area.
3) Damaged starter assembly from animal infestation or debris sucked in from leaf blowing. All you can do is buy a replacement unit and swap it up.
Good luck and be safe!
Mar 06, 2015 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
Cord broke for my leaf blower-how do I fix?
Remove the starter mechanism from the blower motor. Either purchase the same size cord from a saw service shop, or just have them fit a new cord to the starter if you don't feel comfortable about replacing the new cord. Good luck!
May 17, 2010 | Garden
Starting cord does not retract on my leaf blower (homelite)
take off starter mechanism, replace coil, or recoil if undamaged. then replace starter rope
May 14, 2010 | Homelite 'Yard Broom' Leaf Blower
Need to find the oil to petrol ratio for Husqvarna 132 HBV blower
50:1
50 parts fuel to 1 part oil. The easiest way is to purchase the little premix bottles of Husqvarna oil- one bottle to one gallon of fuel. You can find premix oil bottles at the dealer that sold the blower.
Nov 20, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Starter pull cord broke off
You can buy a new pull cord or start a any lawn an garden shop
Nov 09, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
2,437 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
