Question about Microsoft Windows XP Home Edition
Extended desktop rotated, can't turn back.
My primary computer is my laptop but I use an extended desktop on a second monitor. Stupidly, I turned my keyboard upside-down and banged it against my desk to remove some crumbs. I don't know what I hit, but my displays became disoriented. One was upside-down and the other was 90 degrees off.
I have figured out that hitting Ctrl+Alt+arrow keys will let me turn my display around. However, it turns both monitors at the same time so I can only get one to orient the correct way while the other is always 90 degrees different from the first.
I have tried turning off my extended desktop and restarting, but when I re-extended the desktop, it was still oriented incorrectly.
I also tried turning off my extended desktop and tried to use Ctrl+Alt+arrow keys to orient my primary monitor (the laptop) to the same wrong orientation as the secondary monitor. I was hoping that I could then re-extended the desktop and rotate them both together to the correct orientation. But when I turned off my extended desktop, pressing Ctrl+Alt+arrow keys no longer rotated the desktop on my laptop at all.
Does anyone know how to rotate a single monitor at a time? I don't think it matters, but my laptop is a Lenovo ThinkPad, my secondary monitor is an Acer, and my keyboard is an Logitech.
  • Anonymous Jan 17, 2009
    Same
Click on the extended monitor which is out of sync with the main monitor and click CTRL + ALT + UP
Thanks,
Vasu
Posted on Oct 23, 2012
Go to Control Panel -> Screen resolution ->Orientation in this box choose Landscape.
Posted on Mar 22, 2013
  • 186 Answers
Disable one and fix it then disable the other and fix it voila
Posted on Oct 02, 2008
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
Dual screen wont work
Kevin,
1) You cannot plug a monitor into the VGA connector, on the back of the desktop computer, AND plug a second monitor into a DVI connector, on the back of a desktop computer.
In otherwords you can only plug ONE monitor into the motherboard.
[ The I/O area on the back of the desktop computer, is the Input/Output area. This rectangular area has connections for Input devices, and Output devices.
Examples such as a Mouse, Keyboard, (INPUT), VGA devices, (VGA monitor - Output), USB devices, audio devices, (Speakers - Output. Microphone is an Input device), and so on.
The I/O area has a rectangular metal shield. (Thin metal plate)
Connecting a device in the I/O area, is connecting it directly to the motherboard.
Example of a VGA connector, and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(There are several variations of DVI connectors.
Scroll down ]
To use dual monitors you need a graphics card also.
Graphics card with a VGA connector, or DVI connector. (Or both)
Monitor with VGA cable, plugs into the I/O area on the back of the desktop computer. (Plugs into the motherboard's graphic chipset)
The second monitor plugs into the graphics card's DVI connector, or VGA connector.
[ Just an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1416091&CatId=3669
On the image of the graphics card on the left;
Go under it to the subheading - + 11 larger images and views.
There are 7 views shown. One is the carton the graphics card comes in. (View 2 from the left)
Going from the left side, count over to the 5th view. Left-click on the 5th view. Shows you the 'business end' of the graphics card.
Starting at the left side it is the HDMI connector, then VGA connector, then DVI connector.
Note*
YES, you can plug a VGA monitor, AND a DVI monitor, into this type of graphics card, and have Dual monitors ]
FIRST:
Computer on, Windows running; Put the Installation disk (CD) in the optical drive's tray. (CD/DVD drive)
Load ALL software.
Drivers, and 'Control Panel'.
Graphics card software loaded, close all windows, go back to your desktop screen. Turn the computer off normally.
Unplug the computer from power. Open the computer case.
FOLLOW Anti-Static Precautions.
(Don't know Anti-Static Precautions? Post back in a Comment)
Physically install the graphics card. Close the computer case.
Plug the VGA cable of the Primary monitor, into the VGA connector in the I/O area, on the back of the desktop computer.
Now plug the DVI cable of the Secondary monitor, into the DVI connector on the graphics card.
(The main monitor you use is the Primary monitor. The second monitor you are going to add, is the Secondary monitor )
Plug the computer into power. Both monitors plugged into power, turn them BOTH on.
Turn the computer on.
When Windows loads you will see a display on the Primary monitor.
Your desktop screen.
Now Right-click on an empty area of your desktop screen.
In the list at the bottom, Left-click on - Properties.
In the Display Properties window that comes up, left-click on the -
Settings tab.
You will see two rectangular icons. 1 and 2.
1 is the Primary monitor. 2 is the Secondary monitor.
Left-click on the Secondary monitor icon.
Go down towards the bottom/middle on the left.
Left-click in the empty square to the left of -
Extend my Windows desktop onto this monitor
Go down to the bottom Right. Left-click on Apply.
Go down to the bottom Left. Left-click on OK.
Your desktop screen will now be on the secondary monitor.
When you open your internet browser, (Yahoo, or Google, or MSN, or Mozilla Firefox, etc), you have to DRAG the screen onto the secondary monitor.
(Let's use Yahoo for an example. Yahoo will be on your Primary monitor.
You need to drag Yahoo onto the Secondary monitor)
Which direction you drag, is up to which direction the two monitors are sitting, on your computer desk.
The way the monitors are sitting in Display Properties; the Primary monitor is on the Left. ( 1 )
The Secondary monitor ( 2 ) is on the Right.
This is the way the two monitors should sit on your computer desk.
(There is a way to switch them around, however)
On your Primary monitor, (Still using Yahoo as an example), go to the RIGHT side. See the blue frame going around the screen?
When you bring the mouse cursor ON the blue frame, it turns into a Double-Sided arrow.
It is difficult at first to keep the cursor as a double-sided arrow.
Move too far to the right, it turns into the usual pointed cursor.
Move too far to the left, and it turns into the usual pointed cursor.
have to keep it on the blue frame.
WHILE the mouse cursor is a Double-Sided arrow, left-click, and hold the left mouse button down. Now drag the screen to the Right.
(Move your mouse to the right)
Keep dragging until the Yahoo browser is on both monitors.
Different size monitors? The display will not be the same size, on both monitors.
[ I use an HP 2009m, 20-inch widescreen monitor, as a Primary monitor, and an RCA EN-V, 26 inch HDTV, as a Secondary monitor.
I have my desktop on the Primary monitor, and FixYa, (Firefox browser), on the Secondary monitor, right now ]
If this is not your problem please state in a Comment.
Also state additional questions in a Comment.
Regards,
joecoolvette
May 10, 2012 | Computers & Internet
I accidentally disabled my laptop monitor while trying to use another one. How do i turn it back on? dell latitude 610
You should be able to disconnect the external monitor, and then restart the computer to recover your defualt monitor.
If not see if oyu can move your mouse around enough to see the mouse on the second monitor, from there it depends on which operating system you have. That particular dell has XP...
So you would right click, go to properties, Settings tab, then click on the monitor you want to activate. Look for the check boxes, and click extend my windows desktop onto this monitor, then check the use this device as the primary monitor.
Jul 16, 2011 | Dell Inspiron 9400 Notebook
A few months ago my screen started distorting the picture now and then, and then would revert back to being fine. Now it stays mostly like that. I have it set up as an extended display from my laptop. I...
The resolution for the extended display could be wrong or on a setting the monitor cannot display. When you tell the computer to extend the display their should be a resolution drop down. Change it for the extended display monitor ( Click Advanced Display Settings or you may have to click the second monitor to see the resolution for it)
Jun 01, 2017 | Acer AL1912 19" LCD Monitor
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Extended desktop
display properties change labtop to default monitor
Jun 17, 2010 | AOC 193P+ 19" Monitor
IMAGE DOENT DISPLAY PERMANENTLY
Is this connected to a laptop?
If so, you need to be sure that you have the monitor output set for an external monitor.
Do a right clock on the desktop, select the bottom item to personalize your display. Select Display Settings and choose to display on both monitors. I usually use the extended display so that I get two screens. If you just want one screen, you select the external monitor as the primary monitor.
May 22, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Extended monitor wont extend
can you now see 2 monitor properties i.e. 1 & 2... then identify running monitor ... if it is 1 then select 2 in properties and set it again to be used as extended desktop... open any application and pull or drag it holding it from title bar to the extended desktop....
May 31, 2009 | Acer AL2016W 20" LCD Monitor
Remote connection doesn't display secondary monitor
I dont think it is possible to view anything but the primary monitor. I have used VNC many times as well as Crossloop (vnc program) never been able to view beyond that screen
May 28, 2009 | Dell Computers & Internet
Extended Desktop is set as primary monitor
Go to Start, Control Panel, Display, Settings. Here you can change the primary for the secondary and then selecting which will become the primary again.
Apr 02, 2009 | Sony Computers & Internet
Microsoft Windows XP Home Edition Logo
1,654 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
