I get no signal whentrying to program remote - Televison & Video
    Sergeant:
    Champion:
  • 223 Answers
I think that either you have a problem with your ariel or the tuner has dry solder joints or the tuner unit itself is at fault. Hope this helps.
Posted on Oct 02, 2008
Program the remote to another TV
if it is not a universal remote it probably will not work for a different TV
Dec 25, 2016 | Televison & Video
Tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Switch ignition ON.
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Switch ignition OFF.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
  • Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
on Mar 26, 2015 | Televison & Video
Why would my battery be draining after trying to program a keyless entry remote with no luck
Just guessing, but maybe your car is still searching for signal from remote? Kind of like when our phones are roaming for signal...
Oct 10, 2017 | Cars & Trucks
What is the code list please?
An electronic device with remote control has some infrared signals to control it. An universal remote control contains inside some sets of infrared signals. Every signal set has an identificator or code. So code list is document with signal set identificators. It needs to program your remote control to act to controlled device (TV, DVD, etc.)
Mar 31, 2015 | One For All Televison & Video
We have also lost the manual for the RCA DTA800B1 converter box and need instructions to program the remote to work with a Sharp TV.
Press PGM on the remote control. The signal indicator on it remains lit.Enter the 3-digit program code with the number keys. Press OK The signal indicator will be o when the program is one.Press the volume keys on this remote control to check if they can adjust the volume of your TV set.• If you fail to control your TV set,repeat steps 2 to 4 to program again. Try another program code if there is more than one for your TV brand.• If the signal indicator remains lit after blinking four times, you may have
entered the wrong code. Repeat steps 3 to 4 to program again. Make sure you have correctly entered the code.• You can still use your TV remote control to turn on your TV set, select input source and control the volume.for conrmation.your sharp tv code is 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298
Sep 16, 2011 | Televison & Video
CD-ROM drive, whentrying to read a video DVD shows "A disc with unsupported file format" What does this mean?
that means the dvd is written in a different language and needs to be redone in a file format that is compatible with unit.you can find such programs on line to do that .just googel freeware and do some lookn im sure you will find more than one that will work for you .good luck
Oct 30, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Can i program my cable remote for my blu ray player
Hi
I'm Sorry, you cant use an Infrared signal Remote for a blue signal Sony BDP- whatever BluRay Player.
Only a BDP-B101A - B105A gives a blue light signal for S300-S550 to get past the opening menu.
It will not sink
May 21, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
New alarm fob for pt cruiser not coded to car (correct serial numbers)
Programming
When
Remote control added or replaced. System malfunction.
How
Switch ignition ON. Press and hold lock button Fig. 1 [2] for approximately 10 seconds. Keeping lock button depressed, press and hold unlock button within 10 seconds. Programming mode activated (acoustic signal will be heard). Proceed as follows: Release lock/unlock button. Complete the following within 30 seconds: Press lock or unlock button of first remote control. Correct programming indicated by a single acoustic signal. Press lock or unlock button of second remote control. Correct programming indicated by a single acoustic signal. Repeat above procedure to program any remaining remote controls. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 remote controls can be programmed.
Feb 03, 2010 | 2001 Chrysler PT Cruiser
NEED TO KNOW HOW TO PROGRAM A REMOTE PAD FOR A MAZDA 626 EX 1995 PLEASE I REPLACED THE BATTERIES AND EVER SINCE THEN THE REMOTE DONT WORK
1. Remove key from ignition.
2. Close all doors.
3. Open driver side door and leave open.
4. Insert key in ignition, Turn key to ON (as far as you can go without starting the engine) and OFF, Remove Key.
5. Repeat step 4 two more times, making sure you remove key each time.
6. Close and then open the driver’s door three times.
7. Buzz sound or chime should be heard at this point signaling that the vehicle is now in programming mode. If not,
wait 40 seconds and return to step 1.
8. All transmitters need to be programmed at this time, including the old ones. Push any button on a transmitter two
times. A buzz sound to chime should be heard at this point signaling that the vehicle has accepted the new
transmitter code. Repeat for next transmitter, up to a total of three remotes (including any old remotes).
9. After all remotes are programmed, wait 15 seconds or until you hear four chimes signaling successful
programming.
Good luck and this should work.
Dec 09, 2009 | 1995 Mazda 626
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
