I need the settings to put this flat screen on my computor LCM 20-v5 ser# W2005cmc063905801
  • 1,879 Answers
If it is going to be the only monitor, plug it in (that will depend on the type of connection both LCD & computer supports VGA / HDMI).
if it is going to be DUAL monitor, check your video card driver and look for anything that says DUAL MODE or DUAL SCREEN.
provide additional information please : description of the cable from the LCD (what it looks like), video card driver (nVidia or ATI), is it the only monitor or not
Posted on Oct 02, 2008
    Genius:
  • 3,422 Answers
HI,
Please click on the below link to view the user manual:
http://www.westinghousedigital.com/pdf/47_User_Manual.pdf
  • Priya darshan Oct 02, 2008
    Please don't forget to rate or accept the solution.
  • 6,487 Answers
Can you please provide us also the barnd and model of your video card because its important so we can provide you the correct settings....You can also try this connect this monitor to the DVI port on your video card output then restart the computer and if you have teh setup CD for this monitor just run it and let it configure the settings for you...
Hope that helps............
How much freon 2008 chevy aveo?
hi
this should do it
thanks
2008 Chevrolet Aveo L4-1.6L
Heating and Air Conditioning Specifications, Capacities: Refrigerant System Capacities (V5 System)
Jun 11, 2015 | 2008 Chevrolet Aveo
WESTINGHOUSE LCM-20-v5 spots and lines on lcd screen. Is the display bad?
Yes most likely. The best test would be plug it into another computer. If the lines and spots still exist then you can be 100% certain the monitor is bad.
Feb 25, 2013 | Computers & Internet
Turn signals wil not work all other lights work could it be fuse
well there are actually 9 fuses in question here
these fuses power the LCM (lighting control module)
most of the time diagnoses will lead to replacing the LCM
there about 20 tests needed to confirm but a good guess is to see if the hazards work
and the final variable is the multifunction switch
if I had to guess right now I'd lean more towards the multifunction switch only because it's cheaper!!!
but my gut tells me its the LCM
May 22, 2010 | 1998 Lincoln Town Car
WHEN I CONNECTED MY COMPUTER TO THE VGA PORT ON THE TV MY COMPUTOR FAILED TV IS AN RCA 42 INCH FLAT SCREEN
WHAT DO YOU MEAN BY "FAILED"? SOME VIDEO CARDS ARE NOT SET UP OR YOU NEED TO GO INTO YOUR DISPLAY SETTINGS TO SET IT UP. IF YOU DO THAT AND STILL HAVE PROBLEMS PLEASE LET ME KNOW AND I CAN WALK YOU THROUGH IT STEP BY STEP.
Feb 21, 2010 | Televison & Video
Hey my Nam francisco I'm in the Caribbean.
Don't know what you paid for the set but Sony's price for the panel is $620.50, may just need to get new set.
Sep 04, 2009 | Televison & Video
Westinghouse lcm 19w4 has to be used in brightest mode or
I had this same problem and going through the on-screen menus I found a reset option. I reset the monitor settings and the scrolling bars went away. I plan to leave it powered up for a while to see if they come back.
Jan 13, 2009 | Westinghouse LCM-19v1 Monitor
Can't find correct setting for westinghouse lcm22w2 monitor
I don't know if this actually will fix your problem, but all LCM 22w2's are plagued with the 'white screen of death' and eventual power shutoff, including garbage characters and faulty menu, video output, etc. Here's how I fixed it.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supplyboard. This is a common problem plaguing motherboards and LCDflatpanels that use capacitors from Taiwan. If you know how to solder,or know somebody that can, it's actually a pretty easy fix. Take outthe yellow circuit board on the inside, write down the specificationsfor each of the capacitors (the cylindrical things) go to theelectronics supply store and get the replacement capacitors. You can goover the voltage specification (not under), but keep the capacitancevalue matching. Replace one at a time. Go to www.badcaps.net foradvice, tutorials and training on doing this. *You really shouldreplace all the capacitors*, but the very large one next to the powerplug I did leave on the board because I couldn't find a match. To mydelight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
http://www.ctcco.com for professional hosting solutions
Jan 07, 2009 | Westinghouse LCM-22w2 Television
I need a driver for a westinghouse lcd monitor model no. LCM 19 v5
hi,
check out the link for driver
http://www.westinghousedigital.com/details.aspx?itemnum=27
good luck
Thanks
“Don’t Forget to rate the Solution”
Jun 09, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
