Question about Toshiba 46HM95 46" HDTV
Lamp Replacement Replaced lamp wth new one have sound ...but it has no picture ..it says something about reseting lamp?
  • 1 more comment
  • Anonymous Dec 12, 2008
    I now have replaced 3 lamps and a ballast assy. The new lamps do not light up immediately, often not at all after about 8-10 tries, yet the original lamp works fine the first time, every time. Is there some kind of start up or initialization process for new lamps?
  • minton09 Dec 26, 2008
    I have a 46HM95 and have replaced a couple of bulbs with no problem. Now the TV won't start consistently. Reading threads of the other models, I am pretty convinced it is a bad ballast. I'm going to buy a new ballast, and install it. Neither the service manuals or any thread I have read mention anything about conditioning or resetting the bulbs, and I have been through three bulbs in three years...now no consistent starts....
    Good luck.
  • tuffgear Dec 30, 2008
    i have the same problem...it needs a new bulb..should i just toss this tv and get new one..i would like to get a tv that lasts more than 1yr..or even longer..for the amount of money they cost they should last forever.
    Problem Solver:
  • 6 Answers
Color wheel
Posted on Feb 19, 2009
3 RED BLINKS NO PICTURE OR SOUND
With the lamp replacement you also have to go into the setting menu and reset the lamp hours down to zero. If you do not do that the projector is not recognizing your new lamp.
Jul 26, 2014 | Sony KDF-46E2000
Replaced lamp and i still have a yellow light and no picture
Check that your lamp fan is working. It may also be a bad ballast for the lamp.
Mar 08, 2012 | Toshiba 65HM167 65" Projection Television
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
I've replaced the bulb in my tv and the red lamp light is staying on with no picture or sound. What can i do to get my picture back?
Did you put back lamp cover after lamp replacement?
Make sure lamp cover has been fixed in its place securely after lamp replacement.
Aug 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv image will not show , it turns off it says ... something about the lamp inside the tvneed to be replaced?
The lamp timer on your unit has reached the max hours. it needs to be reset. There should be a reset feature in the menu. You should replace the lamp. It will brighten up your picture too. It must be done soon as once the timer reaches a limit your unit will not turn on at all. Check your manual for proper lamp type and replacement proceedure.
Feb 27, 2010 | Panasonic Televison & Video
Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Feb 03, 2010 | Toshiba 62HM95 62" DLP HDTV
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
HLP5067W Going on and off
Sounds like the bulb needs to be replaced. With the tv you have the Bulb last about 6000-8000 hours. If you think that is about right then you it most likely is time ro replace. You should be able to find the replacement bulb from the manufacture and then find it online to purchase.
Sep 20, 2008 | Samsung HLP5067W Television
No picture and no sound
simply unplugging the TV and turning it back on if started to work.
if it doesn't then the Trying a new lamp first is reccommended.
After all, you will need another lamp eventually.
Samsung Parts
http://www.samsungparts.com/
model HLM507W as two different lamp replacement part. the LAMP for my TV was BP960224A. the replacement lamp listed on the Samsung site is BP960224C which was replaced by BP960224J. the difference according to my supplier is that A part has a brown power coupling and the J part has a black power coupling. hope this helps someone in the future. The couplings are different and a black LAMP coupling will not fit a brown TV coupling.
Replacement is simple, getting the right bulb is tougher. Make sure the TV is unplugged and the lamp has cooled. Looking at the TV from the back there is a lamp cover on the lower right. Remove the single screw, remove the door. There are two screws holding the lamp in, loosen these. Then flip the black plastic handle up at the bottom of the lamp assembly and pull the lamp assembly out.
Note the brand of the buld and the color of the connector (black or brown) and then call to order your parts from Samsung's parts reseller
With set off...mute + 1 + 8 + 2 + power.
Arrow down to "Options" push enter.
Lamp reset and lamp hours should be in there.
Power off 2 minutes or until fan kicks off to exit.
BP96-00224C LAMP ASSY./ PHILLIPS 40''-50'' $199.99
Jan 28, 2008 | Samsung HLM507W 50" Rear Projection HDTV
WD-52525 Lamp failed 2x in 4 months..is it the Lamp?
do you get an error code? hold the MENU and DEVICE buttons when turning on the TV and get error code
Oct 20, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 46HM95 46" HDTV Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
