Question about Mission M5AS Subwoofer
Mission M5 as
I'm a skilled technician and I've repaired several amplifiers but I*ve absolutely no plan of this amp.Symptom is the relays doesn't click and so you can't here a sound. But the fuse hasn't blown up and the transformer delivers ye,bl,ye 24,2 V AC and after the rectifier + - 32,3 V DC and red,white,red 44,9 V AC and rectified + - 61 V. So this seems to be o.k. Then I've looked for the power transistors. On the bigger plate there are two 2SC3519 and two 2SA1386 .They have no internal conduction and I can measure ~ 0.6 V Ube. This should also be good. But on the little plate the is also a pair of these power-transistors and there i can't measure a Ube.
So i will solder them out. But i don''t understand how the amp really works.
A there 3 quasi paralel Complementary power stages (push pull ),
What i need is at least a schematic diagram or a service manual . I even don't know the correct idle current. I would be very happy if you could help me With kind regards M.Reinhardt
  • hoshimi Dec 04, 2008
    Not sure if I have the same problem, but my unit seems dead. I would like to have the schematics to do the failure analysis from. Can you help me ?
  • Anonymous Mar 09, 2009
    i have a similar problem, the amp just stays in stand by mode. i replaced the power transistors because they were shorted but it doesn't seem to want to fire up.
  • 4 Answers
SOURCE: Mission speakers...i think i've blown one of them...
I'm guessing you mean one of the bass drivers (as standmount or floorstanding speakers don't have subs as such). Place your hand lightly against the driver when playing some music at normal volume, there should be some vibration (this increases the louder you play). If there's no vibration, you're probably right.
Contact Mission, who can send you a new driver, contact a Mission dealer to see how much it'll cost to go through the dealer network. I'd recommend going down the latter route if you are unsure of what to do yourself.
Just noticed you posted this in March, in which case, I hope you got it fixed (or are enjoying your new pair instead!).
Posted on Dec 04, 2008
  • 10 Answers
SOURCE: blown fuse in mission 700as subwoofer
if you have access to a multimeter, you should test you impedance (ohms) Ω, check to make sure the speakers reads higher than the amplifier needs; this will result in less strain on your amp and diminishement of sound...For example: if you connect two 4Ω
speakers in series it results an 8Ω circuit (least strain). and if you'd take the same two speakers and connect them in parralelle it would result in a 2Ω circuit (most strain).
Posted on Jul 24, 2009
Icebassman 5
  • 57 Answers
SOURCE: Mission 780s (from early 1990s) tweeter gone?
Hi there.
Do you have the make and number on the back of the magnet?
Check if the tweeter is at all available on the net!
To have it repaired is also an option.
Iceman.
Posted on Nov 05, 2009
dunnbiker
  • 8546 Answers
SOURCE: I've just been given a
Leave the brass plates in place and make sure they are TIGHT. They're for separating the internal drivers so one could power them with separate amplifier sources - bi-amping.
Connect the plus and minus speaker cables traditionally, one to either pole.
Removing the plates would silence whichever speaker is NOT amplifier-driven.
Posted on Feb 13, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have this mission 782 for many years! It happen
It's bi-wireable (BUY-wire). Did it occur to you that may be a factor if you're using it that way? The jumpers (or lack thereof) on the back allow or disallow the amp(s) to affect all the drivers. You can tie any amp to one or the other pair of binding posts to test them.
Posted on Sep 20, 2011
My Receiver just switched off on its own just now while perfectly working. Now when I tried to switch it on, it just switches off after about .5 second, you hear the relay sound switch on and then off....
As your complaint post indicates, there is a malfunction to its power amplifier output. Proper checking should be done to this stage by anu well experienced service technicians. Most of the components in the section carries high current, and proper care should be given whe repair this stage. Power output section of your amp is faulty, It switches on first without any problem, but after stabilisation, outputs the power to speakers [relay click indicates that]; then detects some short and shuts OFF. Thie is happening now. Get it repaired by any experienced service pwersonnel have experience in serivcing Hi-Watt amps. OK.
Aug 21, 2011 | Yamaha RX-V420 Receiver
CTS 4200 4 channel CROWN power amp I changed 2 output transistors on channel 1 they were both bad but I am still seeing a fault on channel 1. I tried changing the relay for that channel but the relay...
Try changing the emitter resistors near the parts you've replaced. Also when you change out transistors it's a good idea to change them ALL out..The "supposedly good" ones may be badly stressed.
If the output line to the spkr relay has more than a volt on it the amp will stay in Protect
Jun 24, 2011 | Crown CTS4200 4-Channel Amplifier
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
Dear specialists, I've faced with error with BO Report: The excel file is updating every 15 minutes, but since yesterday BO creates corrupted excel file. Status of appropriate schedule:...
Excel unable to read file is able to resolve Excel repair worksheets, fonts, formulas, cells, columns, rows and etc. Software gives back excel data crashed by any reasons: viruses, incorrect actions anti-virus software, hard drive failures. Tool has the compatibility with Windows 98 and higher. Its interface doesn't require special skills and is simple for novices.
Jun 03, 2011 | Business Objects BusinessObjects...
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
Constant humming regardless of Tuner or Cd or Aux settings. Pops when I shut if off too.
This could be several Things. if your getting a humming:- Possible loose wire/Connection at plug/socket outlet et,c. Pre-Amp/Amplifier problem on PCB ( printed-Circuit-Board of actual device ) fets et,c.
The pop at shutdown, would most likely be Amplifier Problems.
Recommendations:- return the base-item to an electrical goods repair Specialists, For an estimation/Quotation.
Mike @ compurepair.
Nov 04, 2009 | Teac EX-M5 Shelf System
Do you have spare parts (control modul) for AKAI AM-M5
i.ve got a akai am m5 amplifier plus tuner tape deck etc baezaham@gmail.com
Oct 15, 2009 | Audio Players & Recorders
I have a yamaha amplifier in here for repairs, the model no is A500, i cannot get the speaker protect relay to come on, i have replaced all the transistors & capacitors in the speaker protet circuit to no...
Measure DC to ground on the output transistors to check for any offset. The protect circuit is the least likely to be the problem. Post the readings here and I'll guide you from there.
Dan
Mar 11, 2009 | Yamaha XS-350 2-Channel Amplifier
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp problems
From the above symptom, it show that the output stage of the amplifier have some problem.The protection cct come in to cut off the amp. when the output shorted or have Dc voltage.( this is to prevent further damage to the amp. & speaker ).If you know how to repair , just check on the pwr transistor (with heat sink )or else send it to the repair center.hope it help.
Aug 21, 2007 | Harman Kardon SIGNATURE 2.1 Amplifier
Mission M5AS Subwoofer Logo
143 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
