Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Wireless router doesn't stay on
Whenever I plug the router in, the lights flash on for maybe 10 seconds and most, then go out. Obviously I can't get through the startup CD with this problem. The wizard recommended holding the reset button for 10 seconds then releasing and waiting for the lights to go out; that never does anything.
  • D-Link Master
  • 6,487 Answers
Try this one press and hold the reset button for the router for 30 seconds while its power ON then after that power down the router for 10 seconds then plug it back in, then try to run the setup CD again for the router and by the way dont forget to disable the security software installed on your computer because sometimes it will block the connection of your router to your computer.
If still having the same problem this router may be bad and you can try contacting Dlink for further troubleshooting or better have the router replace if its still new...
Hope that helps...........
Posted on Oct 02, 2008
    Novelist:
  • 143 Answers
Check the power source.
if the power source is verified to be working ok, try to press the reset button for 30 seconds to a minute while it's plugged in to the power source then turn it off for another 30 seconds then turn it on.
if the problem still persists, there could be a problem with the device itself and if it's still under warranty, replace it
I installed my DIR-615 router about 2 years ago and set it up with wired, not wireless, connections. I have forgotten my admin password and can't get into the router firmware to reconfigure for...
If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Jul 07, 2011 | D-Link DIR-615 Wireless Router
Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
Wireless connectivity failing
Maybe try to reset it with a pin or pen on the backside,and configure it all over again.
Feb 09, 2010 | Dell Wireless 2350 Router
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Automatically Resets itself every 15 seconds
Check the reset buton it may not put properly adjusted, so it may be put the evice abck to reset. if this is okay, try and put off the device disconnect all cables that link to it. put it on without connecting it, then see if it is rest it self, it it doesn't then plug the cable one by one. this should help. good luck
Jun 12, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Internet Connection breaks
try to reset the router there should be a button underneath or at the back you will need to hold it in for 10 seconds maybe then unplug it then plug it back in see how you get on with that
Dec 12, 2007 | Computers & Internet
On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Nov 10, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
69 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
