Question about Garmin Rino 120 2-Way Radio
RINO 120 :: screen blanks out with just a single horizontal line
Rino 120: Not used for 12 months, never damaged or impacted, fresh batteries, installed, unit functions perfectly, contrast is perfect, then 2-3 minutes later, unit freezes and screen blanks out with just a single horizontal line 1/4" from bottom. battery removal required to regain any control or functionality.
  • 2 more comments
  • Driver_851
    Driver_851 Oct 02, 2008
    created this problem with a clearer description of problem in subject line
  • Driver_851
    By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
    The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
    To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
    go down until your on the "Setup"(hammer)
    go in (by pressing in, on the directional button)
    go down until your on the "System"(gears)
    go down until your on WAAS, go in and select the Disabled
    go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
    Wonder what WAAS is?
    http://www8.garmin.com/aboutGPS/waas.htm...
    Take care.
    PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
  • Driver_851
    I can't solve my own problem?
  • Driver_851
    If my solution worked for your go ahead ahead copy/paste (repost) my answer
    so that my Solution shows as solved (endorsed by you).
    Seems that FixYa.com won't let me fix my own problem ?!?!
    Problem Solver:
  • 13 Answers
Had to wait 24 hours to be able to post my own answer
http://www8.garmin.com/aboutGPS/waas.html
Take care.
Posted on Oct 03, 2008
How come the garmin 120 radio isn't compatible with standard Motorola walkie talkies
When programmed to the same frequency and code settings the Garin Rino 120 should match the Motorola TalkAbout line of radios. They are all using the same UHF FRS/GMRS frequencies. Here is a link to the Garmin user guide where you will find the frequency charts on pgs. 100-102: http://www.uky.edu/~jmlhot2/courses/for480/Rino120_OwnersManual.pdf
Motorola TalkAbout user guides can be found at: http://shop.giantintl.com/Manuals.asp
Best regards.
Nov 20, 2014 | Garmin Rino 120 2-Way Radio
Blank screen when powered up
Other than a major failure, the primary cause would be a bad or poorly charged battery.
Mar 13, 2014 | Garmin Rino 120 2-Way Radio
Instruction
Download or view the .pdf Rino 120 Owner's Manual here........
http://www8.garmin.com/manuals/Rino120_OwnersManual.pdf
Dec 10, 2008 | Garmin Rino 120 2-Way Radio
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Batteries die quickly - unit gets hot
You may have a bad or shorted battery pack. You might try replacing it to see if the problem goes away. It would be normal, while charging for a battery to get warm. But not hot. Rechargeable batteries have a life expectancy of 18-24 months.
Oct 11, 2008 | Garmin Rino 120 2-Way Radio
Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Oct 04, 2008 | Garmin Rino 120 2-Way Radio
LED does not work
you have damaged the screen and it will likely need replacement. there is one other possibility... you may have loosened a connector inside the radio... tap it gently with your finger to see if there are any changes in the display
Robert
Sep 20, 2008 | Garmin Rino 120 2-Way Radio
Turn it on - black screen
Dropped the rino 120 and the led is blank but radio works
Sep 01, 2008 | Garmin Rino 120 2-Way Radio
Broke rino
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Mar 12, 2008 | Garmin Rino 120 2-Way Radio
Garmin 120 just dies
hi
have you put fresh batteries in
are they the right way around
are the 2 metal spring clips tight up against the batteries
try bending them (al little) to make better contact
has the unit had any water in/on it
is the mic button pushed down and draining the batteries too quickly
D
Nov 21, 2007 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
443 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
