Go to the following page on Microsoft’s website and select Continue, then Download. When prompted to Save or Open, select the Open option and follow the directions.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&DisplayLang=en
If this does not work, try Option 2.
Option 2:
Go to the following page on Microsoft’s website and select Download. When prompted to Save or Open, select the Save option and save it to a location on your hard drive.
http://www.microsoft.com/downloads/details.aspx?FamilyId=4B1F5D0C-5E44-4864-93CD-464EF59DA050&displaylang=en
When the file finishes downloading, double click on the file to run it. You will be prompted for a location to unpack the files to. It is recommend that you use something easy to remember such as:
C:\DirectX
Once the files are done unpacking, open My Computer and go to the folder the files were unpacked to (from the previous step). There should be a file in this folder called DXsetup.exe (or DXsetup). Double click this file and follow the instructions.
Once DirectX 9 is installed, your computer will need to reboot. After it has rebooted, you should be able to run Prison Tycoon 3.
