I have a SANYO AWM-1900U CD player/stereo where I get no AM or FM reception(no static or nothing!)but the CD player works fine. Speaker wires are connected properly I just get Zip from the tuner???
    Sergeant:
    Champion:
  • 223 Answers
You might have to invest in a proper ariel not the kind you get that you stick on the wall but a proper FM one that sits in your loft on on your roof. Hope this helps.
Posted on Oct 02, 2008
Can i connect an external antenna to a sanyo awm 2000u stereo for better tuner reception?
Your stereo came with a piece of wire attached at the back. This is/was the FM aerial. It should be roughly 1 metre or approx 38" long. There is no socket on the back of this stereo to attach an external FM aerial. So if the wire broke off then you're going to have to either attach some new wire to the stub, or open the set up and solder directly to the circuit board.
The exact cable lengths for an FM antenna to pick up 88-108 MHz is 37.66" long.
Sep 12, 2014 | Audio Players & Recorders
Sanyo stereo AWM-2700U, cd player says'' door'' just blinking.
Press Eject button while tapping on the top. It should open
Dec 28, 2010 | Sanyo AWM-2800 CD Shelf System
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
AM Reception
what kind of car are you driving. on some cars the antenna need to be extended in order to recieve am reception.
May 27, 2008 | Kenwood KDC-222 CD Player
Reception
Inside the car there should be a splitter between the stereo itself and the antenna in a side plate
behind the dooor kind of under the dash follow your antenna wire from the stereo you should find the splitter along the way it may have came loose or even off
Apr 23, 2008 | JVC KD-G720 CD Player
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
I NEED AN ANTENA FOR PANASONIC SA-PM32DB
If its a one wire or two wire FM/AM antenna your needing just use a length of regular stereo speaker wire or electrical wire at least 5foot in length. Should do the trick nicely.
please rate answer.
Mar 18, 2008 | Audio Players & Recorders
FM static
Hi suebu,
So you got it to go with an antenna. FM tuners are real quiet generally unless they get some sort of signal to unmute them. Even a length of speaker wire split for about 100cm each way(this is called a dipole), then hung vertically will get you great reception.
regards
Graeme
Nov 25, 2007 | Onkyo TX-DS777
171 people viewed this question
 Grubhead
Grubhead
