Question about Microwave Ovens
Kenwood GJ/SS25 microwave.LCD display won't light up.Interior light comes on and turntable revolves and seems to heat food if the start button is pressed.Otherwise unable to use the programmer.
  • 3 more comments
  • rob_1_1_1 Oct 03, 2008
    I have same problem, LCD screen started by flickering and after a couple of days it is totally off and wont come on. But the rest of microwave seems to be functioning (internal light / heating food). Could it be a loose connection? It's still under warranty as it was only purchased in december 07
  • lorrai Dec 28, 2008
    lcd display has suddenly gone off
  • Anonymous Mar 25, 2009
    same model and purchased about the same date....same problem just happened ...no lcd display
  • Ollie_olster Apr 23, 2009
    Same problem, bought in dec 07.
    Same problem. No display
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: I have recently bought a
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
For parts and service, you should contact Kenwood at the number in the owner's manual.
Posted on Nov 25, 2008
I have a kenwood microwave model GJ/SS25. The display does not illuminate but when you shine a torch into the display I can see the numerals very faint. Everything else works
I would be guessing that the display is liquid crystal from your description that a torch will show the numbers up. I would be therefore assuming that the display board would need replacing. You have to be very carefull if you intend opening the cabinet as there is a large capacitor in all microwaves that holds a charge which is capable of killing a person. Even when its been unplugged for days and longer. This can be discharged by shorting the capacitor terminals as long as you dont touch them. Go forth but dont come fifth.
Aug 16, 2017 | Kenwood Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Where can I get a manual for a kenwood microwave GJ ss25?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 09, 2011 | Kenwood Microwave Ovens
How do i change the light bulb on a Kenwood Ken GJ/SS25 microwave
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Mar 02, 2011 | Microwave Ovens
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
Jan 15, 2009 | Sharp R-1481B Microwave Oven
I have recently bought a Kenwood Microwave model KEN GJ/SS25. I notice that the turntable does not revolve. Should it? Regards John Hamon jhamon@hotmail.co.uk
Nov 24, 2008 | Microwave Ovens
Kenwood KEN GJ/SS25 microwave doesn't heat food
Q= my Microwave some time start and some time not; went push start swith it caming sound or click, click. thanks for your replying.
Nov 16, 2008 | Microwave Ovens
Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Sharp R-303CW Convection / Microwave Oven
Microwave Ovens Logo
335 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
