Question about Dell Inspiron 1501 Notebook
Inspiron 1501 problem
Hi, just wondering if you can help, when i press the power button on my inspiron i can hear the fans but thats it, the power and battery lights come on but apart from these things there is no other life
    Scholar:
  • 155 Answers
Look for the numlock light and see if you can turn it off or on by pressing the numlock key. If it responds, you may have a video issue. try connecting a known good external monitor to the laptop. Hit Fn F8 once to thrice until you get video on the second monitor. If you get good video on the external monitor, you may need to reseat/reconnect the lcd cable.
If the numlock light doesnt respond, it may be a loose memory card. try reseating it. You can find it on the bottom of the laptop, right under the door labelled 'M'.
These are just common fixes. There are still some other reasons why it's not booting up.
Comment back if nogo.
If it got fixed. Kindly leave your rating. Thanks!
Posted on Oct 04, 2008
Gray white screen.. Can't hear or feel hard drive or fan
It is unfortunate that the Dell Inspiron 1440 has a Gray white screen. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the same issue then I would suggest you to try connecting a known good external LCD screen and check if that helps.
    Also check if there are any beep codes from the computer, how the power button light behaves and the system LEDs (located along the front edge of the system next to the media card reader).
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 21, 2014 | Dell Inspiron Laptop 1440
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
Hi i have an r630 desktop and it did work but now i have no power to motherboard no fans cpu but i do have power to the hard drives and rom replaced power supply same problem
Maybe your motherboard is toast.
Mar 30, 2012 | Computers & Internet
Error 2000_0333
When does this error occur?
Mar 30, 2012 | Dell Inspiron 15 Laptop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My dell inspiron laptop will not start up tingxuan - Nov 18, 2008 11:19am GMT - Last answer on Jul 19, 2010 3:58pm BST tech Hello, recently I have just switched the hard disk of one of my inspiron laptop...
Hi, I have not spoken to you before, I take it the PC was working fine before you switched hard drives?? If so, check to see if you can boot into BIOS, by pressing the F1 key during doot up. If you can and the previous question is Yes, then I believe you will need to reinstall XP.
Hope this helps
Jul 21, 2010 | Dell Inspiron 1525 Laptop Jet Black
I have dell inspiron 1100 laptop, when i turn it on fan goes on for about 15 sec,with no screen, power lights and battery lights either, i can hear sound from HDD and DVD rom, but after 25 sec everything...
Could be loose battery pack.
A bad memory chip would do this as well. Sounds like your not getting power.
Try this,
Unplug it, remove battery, wait couple minutes, press and hold the power button for 5 full long seconds, wait couple minutes more, then put battery back in securely, then plug in, turn back on.
Mar 07, 2010 | Dell Inspiron 1100 Notebook
My dell inspiron will not turn on. I press the power. the power light flashes for a sec. I hear a quiet click then it goes out.
hi,
-please try to run the diagnostic on the computer
-while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; if computer powers down after the test initialize; it is a possible motherboard failure
-to conclude that it is a motherboard failure check the lights on the laptop, it the lights flashes then computer goes off; it is a motherboard problem
-in addition try to do the test while computer's battery is out of the computer
-thanks
Sep 24, 2009 | Dell Inspiron 1721 Notebook
Dell Inspiron 5160 Black screen on power up
There is a small board that the power button is integrated into that connects to the motherboard. When this power board malfunctions it will cause this issue with the machine. It can, and quite often does, damage the motherboard when it malfinctions. You should take the machine in for a power board replacement and a diagnostic to make sure that the power board hasn't damaged the motherboard.
Jul 14, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 1501 Notebook Logo
300 people viewed this question
Alun Cox
