Question about LG LRFC25750 Refrigerator French Door
Ice maker The icemaker makes ice but will not shut off when full??Thanks
  • 1 more comment
  • ptparas Oct 03, 2008
    The arm will not stay up when the tray is full.
    The arm will not stay in the up position to shut off the ice.
  • Anonymous Jan 25, 2009
    I have a Kenmore model 106.56666501. The ice maker stopped working. I turned the maker switch on and off several times plus wiggled everything I could reach on the ice maker itself.The machine now is making ice but production seems to be slower than when new . Do you have any idea what may have been wrong or what could have caused the reduction in ice production.
  • 943 Answers
Hi. thanks for the question. is the arm on the ice maker in the up position. it could be stuck in the ice cubes. the arm has to he up to stop the process thanks the appliance doc.
Posted on Oct 02, 2008
The ice maker stopped making ice one day
A typical problem with these is some type of bin sensor that tells the icemaker that the bin is full. it is usually some type of "arm" that shuts it off when the ice rises to a level that raises the "arm" to "kill" the icemaker
Oct 01, 2012 | Refrigerators
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
My ice maker on my Kenmore Elite has stop making ice. The water still works, but it no longer will make ice. What can be wrong with it, and how can I fix it?
If the water flow works, I would check the wire that controls the water flow to the icemaker. It shuts off the water when the tray is full and fills the ice maker when it senses that more ice is needed. It typically is over the ice tray. This can be dislodged and reseating it will solve the problem.
Let me know if this doesn't solve the problem. Thanks.
Jan 31, 2011 | Kenmore Refrigerators
The ice maker will not shut off on the LG refrigerator.
the internal switch that is supposed to shut the ice maker production off when the bucket is full has failed. Replace your ice maker
May 07, 2010 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
May 20, 2009 | Jenn-Air JCD2295KES Stainless Steel
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Keeps making ice, i can't seem to make it stop.
You have an emitter and receiver in the freezer section...Actually when you slide the lever on the right side in the middle of the freezer section, you break the beam...and it is suppose to stop the ice maker from harvesting ice anymore. If this shut off device fails, it can fail in the on position and continue to make ice. Replace this assemlby sold in a kit and you will be fine. In the mean time, if you can remove the ice maker head and unplug it, that will stop the ice until you can replace the emitter and receiver assembly. You can also shut the water off but the ice maker will continue to operate, just not dispense ice. If extending and waiting on this repair you should disconnect the ice maker.....
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
BCM45A
unplug and remove 4 screws from front of cover and see if the cam is not broken. every time it dumps ice this cam raises the bar to shut off ice making if the bin is full. may be it just slipped?
Sep 26, 2008 | U-Line Icemaker
Kitchenaid superba icemaker
HI thanks for the question On the ice maker you should have an metal arm thatlifts up &down Down means you want ice Up means the ice bucket is full if that arm is not there that will cause the problem if the arm is there make sure it moves up & down ok if it does Then you need a new ice maker or save money & when the bucket gets full turn off water at back of fridge to stop water from coming in thanksfor the question THe appliance doc
Sep 03, 2008 | KitchenAid (KSRD22FKST) Side by Side...
LG LRFC25750 Refrigerator French Door Logo
412 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
